Originally posted by Fischi
View Post
Chromecast Plug-in - Beta Testing
Originally posted by spud View PostTry to disable any firewall on your Homeseer machine or your router, and set the log level to Debug to get more information when the plugin tries to connect.
Here my .log message:
Nov-02 21:36:46 Chromecast ERROR Not connected to chromecast Wohnzimmer
Nov-02 21:36:46 Chromecast DEBUG Playing http://192.168.178.20/Wave/chromecast20171102213645793.wav on Wohnzimmer
Nov-02 21:36:46 Chromecast INFO (Wohnzimmer): Hello, this is a test for chromecast plug-in
Do I have to do port forwarding ?
Fischi
Fischi
Can you ping the IP of your chromecast from your Homeseer machine?
Originally posted by spud View PostPlease capture and post a debug logs of when the plugin discover the chromecast.
Nov-02 22:05:41 Chromecast DEBUG md = 'Chromecast Ultra'
Nov-02 22:05:41 Chromecast DEBUG Resolved Service: Chromecast-Ultra-3fb2fbf863e54df059cf38109a335d88 - _googlecast._tcp. - 192.168.178.79 - 8009
Nov-02 22:05:41 Chromecast INFO Found Service: Chromecast-Ultra-3fb2fbf863e54df059cf38109a335d88
Yes, I can ping my Chromecast.
Fischi
I tried setting up an event to fire every time a title was set or changed, but that trigger was firing continuously. I think the song must constantly be being set. I also tried an event to fire only when the title had changed, but it wasn't firing at all. Not sure why.
I'm going to try going back to just triggering off of playing and hopefully worst case, we'll have to pause wait and then press play when a cast stream is launched.
I tried seeing how it would work with google play music, and the add-in froze in the playing state after I press "stop cast" from within google play.
Sorry I'm not much help in troubleshooting.
Originally posted by Fischi View PostSpud, here's the debug after detecting my Chromecast:
Fischi
Originally posted by jryan15 View PostI tried setting up an event to fire every time a title was set or changed, but that trigger was firing continuously. I think the song must constantly be being set. I also tried an event to fire only when the title had changed, but it wasn't firing at all. Not sure why.
The title device string is changed but not it's value, so the only way I know to trigger based on that is to use the "EasyTrigger: A Device's string is..." trigger.
Originally posted by jryan15 View PostI tried seeing how it would work with google play music, and the add-in froze in the playing state after I press "stop cast" from within google play.
Please provide some debug logs, if you still have this problem. You are testing with version 3.0.0.8, right?
Originally posted by spud View PostI need to see the full debug logs, you should have more lines than that.
Nov-03 20:19:07 Chromecast INFO Connecting to Wohnzimmer 2
Nov-03 20:19:07 Chromecast DEBUG Resolved Service: Chromecast-Ultra-5ea4de27e0b5bd135c3bf67157be0582 - _googlecast._tcp. - 192.168.178.201 - 8009
Nov-03 20:19:07 Chromecast DEBUG TXT Records =
Nov-03 20:19:07 Chromecast DEBUG id = '5ea4de27e0b5bd135c3bf67157be0582'
Nov-03 20:19:07 Chromecast DEBUG cd = '82F88F12B6480B4FD90F0003602CBC68'
Nov-03 20:19:07 Chromecast DEBUG rm = '94A84799EEA6E005'
Nov-03 20:19:07 Chromecast DEBUG ve = '05'
Nov-03 20:19:07 Chromecast DEBUG md = 'Chromecast Ultra'
Nov-03 20:19:07 Chromecast DEBUG ic = '/setup/icon.png'
Nov-03 20:19:07 Chromecast DEBUG fn = 'Wohnzimmer 2'
Nov-03 20:19:07 Chromecast DEBUG ca = '4101'
Nov-03 20:19:07 Chromecast DEBUG st = '0'
Nov-03 20:19:07 Chromecast DEBUG bs = 'FA8FCA75656E'
Nov-03 20:19:07 Chromecast DEBUG nf = '1'
Nov-03 20:19:07 Chromecast DEBUG rs = ''
Nov-03 20:19:06 Chromecast INFO Found Service: Chromecast-Ultra-5ea4de27e0b5bd135c3bf67157be0582
Fischi
Originally posted by spud View PostPlease test version 3.0.0.8 available in first post of this thread
Until now no more freezing of the status.
But how can I start a .wav file from within a script?
Need it to play my voicemail recordings.
They are in the HTML dir.
chromecast repeats itself.
This is weird, this event has been working just fine. Except today, The chromecast repeated the first sentence five times before saying the first sentence and going on to finish.
I can't say for sure if the other speakers did also, since I was nearer to the chromecast and probably would not have heard the others.
Originally posted by spud View PostYou should be able to use the native Speak scripting function and passing the absolute path of your file as parameter.
response.write (" <TR><TD><A href=""berichten.asp?bericht="&ls_name & """>" & mid(ls_name,39,10) & "</A></TD>")
And the filename a combination of date number called and number received:
79a0a_31497618085-03-11-2017_10-15-05_0631597966.wav
So I can't hardcode it in an event.
When I click on the message, it is played on the PC, but not send to the Chromecasts.
So it is not using the speak scripting.
Can't I use something like Chromecast.PluginFunction(.......)
Depending on the streaming app, I noticed that the "Status" device is being updated every 2 seconds, at least when the status is "Playing". I have an event triggering on just setting (not change) this field, and HomeSeer went crazy.
You can see this when you disable the "Do not update device last change time if device value does not change" field. The last updated field updates every 2 seconds. For instance, TuneIn is causing this behaviour.stefxx
Originally posted by peterpc View PostThe problem is that the absolute path is a combination of variables in an .asp page like this:
Could you post the script you use? The native Speak scripting function should work.
Originally posted by stefxx View PostDepending on the streaming app, I noticed that the "Status" device is being updated every 2 seconds, at least when the status is "Playing". I have an event triggering on just setting (not change) this field, and HomeSeer went crazy.
