Installed the modbus Plug in and tested my events by turning on and off i/o blocks that activate solenoid valves, everything worked. The next day i tried to repeat my results it would not function. My setup was the same and i did not change nothing, though i did notice under the Last Change column the time and date was incorrect. My input keeps running and my outputs state says 5/21/1929
11:00:00 AM.
is there a possible bug in the plug in or what my be the fix?
11:00:00 AM.
