cam6.6 setp issues
    cam6.6 setp issues
    Newbie questions
    I cant seem to get the plugin working.
    tried issuing several basic commands like keypad on or off
    changing the source name
    Cant update to latest version
    log attached.
    Homeseer starts real slow now.
    my profile did not show
    Dell 800 2U server with WIN7
    squeezebox
      Do you have the com port type set to HomeSeer?
      As for updating to the latest, try this:
      1. Disable plugin
      2. Check and make sure that the HSPI_BLRussound.exe is not running (kill it if u have to)
      3. Update the plugin
      4. Re-enable the plugin
      Cheers,
      Bob
        thx blade for the quick reply
        I did try to update with the plugin disabled.
        I will check if the exe is running and try again.
          update worked
          Still no joy on running any scripts
          the keypads are UNO-s2's
            I am using 2 CAV66 controllers and 11 uno-s2 zones with no issues
            On the options page are you using the com port type of HomeSeer?
            Cheers,
            Bob
              yes connected to COM:1
              I checked the serial port settings per russound guideline
                Hmmm... post a screen shot of your options page
                Also, do the following:
                1. Disable BLRussound
                2. Edit hspi_BLRussound.ini and change debugLevel=true and save INI file
                3. Re-enable BLRussound
                Once it has been up and running for about 30 seconds, then go to the options page and disable debug logging
                Attach the BLRussound-Detailed.log file zipped. It is in the HS3 root folder
                Cheers,
                Bob
                  What does com port type homeseer do? I've been using mscomlib since day one.
                  Originally posted by rprade
                    It is just the method of com port control
                    I have found that the "HomeSeer" one works the best for me and I recommend that one for Windows
                    Cheers,
                    Bob
                      Do you think switching to homeseer might help with some of the issues I see on occasion?
                      The issues seem to almost be entirely squashed at this point I might add. Good work Bob and thanks!
                        I switched the port to homeseer
                        stopped and restarted the plugin
                        Using control panel I tested all on command
                        It worked!
                        But the source and zone names still do not update
                        Issuing all off does not work either.
                        Some progress...
                          What controller are you using?
                          I will need a debug log to see why the devices are not updating
                          1. Disable plugin
                          Capture the issue and then disable debug logging and attach the debug log zipped
                          Cheers,
                          Bob
                            log file
                              controller is a CAM 6.6
