Remotes that can be mounted over traditional switches?
    I have been searching for a z-wave remote that can be mounted over a traditional flip switch in my home.
    The reason for this is that my smart bulbs are often powered off by visitors, and since I rent, replacing the switches themselves is not feasible.
    I have found a lightify remote that looks perfect for my needs, but I don't think the HS Zigbee plugin will support it, and I would rather find a z-wave or insteon alternative.
    Does anyone know of any z-wave solutions similar to the link below?
    https://www.amazon.com/dp/B0196M620Y..._t3_B014STZASK
    Thanks in advance
    You might take a look at this one. It seems to do the same as the Lightify but with z-wave.
    https://www.amazon.com/GoControl-WA0...ve+wall+switch
      I think I am going to order one of each, just for curiosity's sake. I'd like to know if the Lightify switch will be recognized through the hub. I really like the lightify switch's appearance more, but it isn't a big deal. I will update after I test the lightify - if it doesn't work I can just return it.
