Hey guys !
Has anyone figured this one out yet ?
I would like to install 2 to 3 heated floor systems with multiple Insteon / venstar tstat units.
With the Insteon Tstat, I would use a 24v relay that will control the 240V load, therefore, cutting power to the element but is there a problem not using the floor sensor that's usually reporting the temp to the original heated floor tstat ? ( Flextherm 120/240GA in this case )
I understand I would be reading the temperature up on the tstat instead of reading it directly in-ground. I would not want to bust a cement embedded system !
Anyone ?
Thx !
Anyone ?
Thx !
