I have recently installed a RFXtrx433 USB controller which is working perfectly, I have also successfully integrated a number of LightwaveRF devices all of which again work as expected. The problem I have is that when adding a device into my HSTouch project I needed the option to "toggle, which isn't available, so I am using a script to check status and then turn off or on. Everything works as expected except that the device status icon disappears when turned on using the ExecX10 command, and then subsequently results in a missing icon in the HSTouch project.
I have used a virtual device as a workaround but this seems unnecessary when all I need is for the status icon to display the state it has just been switched to. Oddly, when turning off using the same command, the "Off" icon appears!
Any help would be appreciated.
