I am adding my Insteon devices to a new Troller Zee system. The devices work OK (ON and OFF) but when I try to turn them on using the Dimmer Function they dim but when I try to turn the light off it just blinks continuously until I un-link the device. I am on the second dimmer test and the same thing is occurring. Any help appreciated.
Erratic flashing on Insteon Dimmer Switches
Please try a factory reset on the switches. And then use the program device for home seer in plugin to rebuild linksMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostPlease try a factory reset on the switches. And then use the program device for home seer in plugin to rebuild links
Also I am running the Insteon Hub in parallel with the devices until I get everything migrated to the new controller. Is this a problem?
Do I need to do a factory reset on the remaining devices before I add them to the new system?.....thank you very much.
You shouldn't need to factory reset every device. Remember when you reset a device, the links to the hub will be erased.
running homeseer/plm and hub in parallel shouldn't be a problems; others do it.
regarding the lag, please enable detailed logging in the plugin, and then control the device in question. Then post a log snippet of the log entries related to the transactionMark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View PostYou shouldn't need to factory reset every device. Remember when you reset a device, the links to the hub will be erased.
Do you think the new PLM has some effect on the problem?.....Or should the "Linked Device:" field be set to "Not Linked"..?....Am i linking the devices to themselves by entering each device in that field on the Configuration page?....
Also when unlinked from the Configuration page there is no lag when it is controlled and the response is great....
That was the problem i think....operator error...What is the purpose of that field on the Configuration page? Linking the device to a different device? and when is that used?....Sorry for wasting your time but I am new to this setup and the learning curve is rather steep for me....Last edited by neutronspin; December 12, 2017, 10:31 AM.
please do not use the HS field "Linked Device Field" with any device created by my plugin.
if you need create an insteon link between two devices use the pluginLast edited by mnsandler; December 12, 2017, 12:51 PM.Mark
HS3 Pro 4.2.19.5
