Script for arm/disarm system
    Im new to homeseer but I have been trying to get a script to work that will take input from hstouch field (code +1) for disarm or (code + 2) for away etc and send it to the plugin but the example in the help file doesn't work as it says that it can not find hspi_vistaalarm.
    Has anyone been able to get a script to work for this?
    scripting for hs3 is different.
    you will need to use the hs.pluginfunctionI() routine to make calls to any hs3 plugin. there should be plenty of examples of how to use this
    Mark
    HS3 Pro 4.2.19.5
      I ended up doing this in a different way.
      I recreated the keypad on HSTouch and created individual events for sending the numbers to the panel, then mapped the HSTouch numbers to the events. So when "1" is pressed on HSTouch it runs the event that sends "1" to the panel.
