Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area > Migrating to HomeSeer (From Another System)
Migrating to HomeSeer (From Another System) Are you migrating from another system to HomeSeer? Use this forum to connect with others who've done the same thing!
Old January 16th, 2017, 04:28 PM
JackN JackN is offline
Seer
HomeSeer for Polling Omni Pro II
I would like to know what HomeSeer hardware/software would be required to poll and store Thermocouple Temp/Humidity and Thermostat Temp from an Leviton/HAI Omni. I have never used HomeSeer but I was told I could do this several years ago when I inquired at Cocoontech.
Additionally, if there are several options, which options would also work with Amazon Echo/Alexa?
Old January 16th, 2017, 11:35 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Welcome to the Homeseer forum JackN.
Homeseer Zee, Homeseer Pro, Homeseer Standard, Hometrollers all support the Leviton Omni Homeseer 3 plugin and yes you can poll Temperature/Humidity, Temperature and Omnistat Temperatures from the Leviton Omni Pro panels.
I did that with Homeseer 2 and doing it today with Homeseer 3 and the Omni Plugin.
For more information relating to the plugin see over here:
HAI Panel for HS3 Plug-in (rmasonjr)
Homeseer includes the Amazon Alexa plugin and you can utilize both just fine.
I am Pete_C on the Cocoontech forum.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers | Openpeak Intel Atom SoC tabletop touchscreens (15 HS tabletop tablets)
HS3 Pro & Lite
Edition Beta 3.0.0.435 | HS3 Wintel Touch | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Tags
omni pro, poll, temperature
HTML code is Off
Omni II Pro with CBus and HomeSeer Kiwi HAI/OnQ Panel (HS2) 4 September 1st, 2011 08:44 AM
Problem Connecting Homeseer to HAI Omni TheCodeMan HAI/OnQ Panel (HS2) 7 September 21st, 2006 10:50 AM
Homeseer and Omni LT acn we Web access warpedtimes HAI/OnQ Panel (HS2) 2 October 24th, 2005 11:31 AM
With Homeseer Plugin, are you able to use the omni screens still warpedtimes HAI/OnQ Panel (HS2) 1 October 18th, 2005 02:24 AM
HomeSeer to Omni Communications anogee HAI/OnQ Panel (HS2) 1 November 7th, 2003 04:35 PM
