Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area > Migrating to HomeSeer (From Another System)
Migrating to HomeSeer (From Another System) Are you migrating from another system to HomeSeer? Use this forum to connect with others who've done the same thing!
Old March 21st, 2017, 02:39 PM
SJM992 SJM992 is offline
Viewer
Coming from VERA - Where's the STOP button?
New HomeSeer user here, coming from Vera. I have a question regarding the control of my Somfy awning and curtains which are connected to Z wave via a Somfy ZRTSI controller which converts Somfy RTS to Z-Wave.
This worked well on Vera because it gave me 3 control buttons (Up, Down and Stop) which replicated the three buttons on the Somfy remote. HS3, on the other hand, gives me just two buttons on the binary switch (Up and Down) - no Stop! The multilevel switch gives me Up and Down plus a sliding scale with % open but this doesn't work - no response from awning/curtains when adjusting the sliding scale.
So, bottom line, how do I make the awning stop? I don't want it to go all the way out, so, on Vera, I set it to Stop after 10 seconds. How Can I do this in HS3?
Old March 21st, 2017, 02:53 PM
mrhappy mrhappy is offline
I'd try rescanning the device a couple of times in case HS has missed that option, I know that I have rescanned some lighting devices and they have come back with additional controls (I ended up with start/stop dimming buttons I never had before).
Old March 22nd, 2017, 07:49 PM
Viewer
OK, thanks. Tried rescanning but it made no difference.
Compatibility (Fibaro, TKB, Aeon, Duwi, Everspring) - coming from Vera JonathanLondon HomeSeer Z-Wave Plug-in 0 August 2nd, 2016 11:51 AM
Button Press Commands Stop Working rustynail HS3Touch General Discusion 0 June 17th, 2014 10:40 AM
Refresh Stop Button? pp HS2 / HSPRO 5 July 19th, 2006 10:15 AM
HSP 2.0 stop speaker clients button not working griffined HomeSeer General Discussion Area 0 August 20th, 2005 09:43 PM
