I have certain conditions when I want to trigger and event, e.g. when coming home I want to control lights based on the time of day. So I created an event with the condition
IF This event is MANUALLY triggered
AND IF The time is 1h, 0m before sunset
AND IF The time is 30m after sunrise
That all works fine if I enter the conditions in the listed sequence (see the bottom part of the attached image).
However, in another instance I first entered the time condition
Then I wanted to add the "IF This event is MANUALLY triggered". However, it is not available as you can see in the dropdown list of the screenshot. So my questions are:
* Why is it not available?
* How can I rearrange the sequence without having to redo everything (sometimes I have similar events with different criteria but when entering it I often choose (not by intention) a different sequence. I would be nice to rearrange the sequence so it's easy to see any potential differences.
