It should report version .8
See --- HS/Setup/Interfaces/ Web page, in the 7th column from the left you will see a column header labeled version, scroll down to see lrpSpeak.dll and it's version.
It does not appear that you successfully unzipped and copied the new file into the HS directory.
Remember since you are replacing an existing dll, you will need to exit HS first, and answer yes to over-write the older dll file.
