Version 1.2
New Features
- Supports multiple partitions
- Adds Partition Triggers
- Supports Vista 50 & 128 panels
- Support ad2usb V2 boards
- Uploads new firmware directly to the ad2usb
- Supports the new serial version of the ad2usb
Fixes
- a bug related to Zone Bypassing
- V2 Ad2usb firmware version ademcoemu_V2_1f_0b.hex or
- V1 Ad2usb firmware version ademcoemu_V1_0f_26.hex
Please reply to this message with issues and bugs
Upgrade Instructions:
Very Important: Please backup your current HS mdb and vistaalarm.ini before begining so you can rollback if necessary
1. Shutdown HS
2. You may install this new version over any existing version. The old version will be uninstalled. Your settings and devices will be retained and upgraded as necessary.
3. Restart HS
4. Configure Partition 1 (at a minimum) on the new Partition page. You will need to enter the device address you are using with the ad2usb and select a devicecode (DC) for the Partition device and the Chime device if you want one.
New User Instructions:
1. Shutdown HS
2. Install the package
3. Restart HS
4. Configure the Com port on the Setup/Interface page for the plugin and then enable the plugin
5. From the plugin Config page, create the zone devices (using the Add Zone feature) to match your actual zones.
6. Configure Partition 1 (at a minimum) on the new Partition page. You will need to enter the device address you are using with the ad2usb and select a devicecode (DC) for the Partition device and the Chime device if you want one.
Enjoy!
Note for Vista users: I have attempted to make this install package compatible with Windows Vista, but can't test it. If you receive an error installing this package, try the following:
1. right click on a CMD icon and select run as Administrator
2. Enter msiexec /i HomeSeerPluginVistaAlarm_1_2_0_0.msi (note: you will need to be in the directory where the msi file exists to run this.)
Enjoy!
New Features
Fixes
1. Shutdown HS
3. Restart HS
1. Shutdown HS
3. Restart HS
Enjoy!
Enjoy!
