Hi Jon,
I am having a strange issue with the DriveMonitor. I have it set up to monitor a number of local drives (e.g. on my HS3 Server) as well as a number of client drives as well.
The client drives are set up, and it picks up the C drive (although the C drive is reporting as 1445.94 gb of 2767 gb (which might be the total of all drives on the machine, but C drive is 232gb in size.
The other 3 drives I have, (2 external HDD,s: 1 x 1tb, 1 x ~600gb, and 1 mapped drive (NAS): ~ 2.4tb) dont show up and I get the following error (below), what is interesting is that the RCCNM works fine ( I did a test turning the monitor off and it worked perfectly):
Nov-02 11:53:27 AM Jon00_DiskMon Error - Cannot obtain drive data from remote client
Nov-02 11:53:19 AM Jon00_DiskMon Error - Cannot obtain drive data from remote client
Nov-02 11:53:10 AM Jon00_DiskMon Error - Cannot obtain drive data from remote client
Nov-02 11:53:10 AM Error A call was made to save a global variable (Jon00RCCNMPort8840) but that global variable has not been defined.
Nov-02 11:53:10 AM Warning A call was made to retrieve a global variable (Jon00RCCNMPort8840) but that global variable has not been defined.
Nov-02 11:53:09 AM Jon00_DiskMon Error - Cannot obtain drive data from remote client
Nov-02 11:53:09 AM Error A call was made to save a global variable (Jon00RCCNMPort8840) but that global variable has not been defined.
Nov-02 11:53:09 AM Warning A call was made to retrieve a global variable (Jon00RCCNMPort8840) but that global variable has not been defined.
Nov-02 11:53:07 AM Jon00_DiskMon Error - Cannot obtain drive data from remote client
Nov-02 11:53:07 AM Error A call was made to save a global variable (Jon00RCCNMPort8888) but that global variable has not been defined.
Nov-02 11:53:07 AM Warning A call was made to retrieve a global variable (Jon00RCCNMPort8888) but that global variable has not been defined.
Many Thanks!
Many Thanks!
