Jon00 Device Grouping Utility (web page) for Homeseer 3 & Homeseer 4
    #31
    a) what are you trying to ungroup? A plugin, own devices?
    b) I assume you selected both parent and all child devices when you tried to ungroup?
    Jon
      #32
      Thanks, issue B)
      Note to self: Read the manual!!
        #33
        Running Script
        Jon00
        Can you give me a few more details on how this script is run? You say to Call Jon00Grouping.aspx via your Homeseer web server.What does this actually mean?
        thanks
          #34
          When you call up the Homeseer device management page in your web browser, you would use something like:
          http://192.168.1.10/deviceutility
          The IP address etc will most likely be different for your setup.
          To call the grouping web page, just replace deviceutility text with Jon00Grouping.aspx
          i.e.
          http://192.168.1.10/Jon00Grouping.aspx
          Jon
            #35
            Thanks, works great!
            Do you have a plugin that creates linkes to your plugin pages in homeseer? That way we dont have to remember the names
              #36
              You can specify up to 4 web pages via the Homeseer Setup/Custom tab which will show up in the links.
              If you want more you can use Jon00 Links.
              Jon
                #37
                Awesome. Thanks again!
                  #38
                  Jon,
                  I have seemed to created groups which I cannot get rid of.
                  I've select all the items to ungroup, but they still remain.
                  Is there a way to revert back?
                  Robert
                    #39
                    did you ungroup the parent device?
                    Jon
                      #40
                      Yes and all the child devices..but no go.
                      I have a backup which I think I'll revert to..
                        #41
                        Copy this to your scripts directory and try again.
                        Last edited by jon00; March 26, 2016, 10:26 AM. Reason: Download now available from my website
                        Jon
                          #42
                          Thanks Jon... That worked!
                            #43
                            Great...I've updated the download on my site.
                            Jon
                              #44
                              jon i updated my homeseer to the last version , but i get an error when i go to the page... i did not do something else , only update homeseer
                              this is the error :
                              Server Error in '/' Application.
                              Configuration Error
                              Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
                              Parser Error Message: Could not load file or assembly 'Microsoft.VisualStudio.Web.PageInspector.Loader, Version=1.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3' or one of its dependencies. The system cannot find the file specified.
                              HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
                                #45
                                I have no idea. Do you have visual studio installed on your HS PC?
                                Jon
