I have a bunch of older GE/Jasco Dimmers, both 3 way and single switch. Using HS2, I was able to alter the dimming rate on these, for both manual control and remote control. A useful feature.
I just added a few newer 12724 switches and I am unable to figure out how to alter the dim rate in HS2. Its just not there.
I have HS3, been putting off the migration, but I figured maybe it would be doable from the newer software. But no, all I see are LED and switch reverse options. Even worse, I don't see the dim rate options for the old switches in HS3. Is it somewhere other than the settings page with the LED options?
