Go Back   HomeSeer Message Board > Camera Plug-ins > Camera Discussion > HomeSeer NetCam Plug-in
HomeSeer NetCam Plug-in The NetCam plugin provides access to network based cameras.
Old January 6th, 2017, 08:27 AM
stefxx's Avatar
stefxx stefxx is offline
NetCam Path issue on Linux
I am using the NetCam plugin on Linux, and it works just fine. However, I always have a directory created in the root of my machine called "HomeSeer\html\netcam\" (yes, that is the name including the backslashed). Obviously it should be "/HomeSeer/html/netcam". It does not seem to cause issues, but removing the directory only causes it to be recreated...
Small annoyance, I know. However, it would be great if this could be fixed.
stefxx
windows path in linux bje BLRussound (3P) 24 January 7th, 2017 05:18 AM
Will NetCam be ported over for the Linux platform? dhalsall HomeSeer NetCam Plug-in 0 September 8th, 2016 11:59 PM
Netcam plugin for Linux? WfromL HS3 Plug-In Development 2 August 29th, 2016 05:22 PM
Linux installation issue karib HS3/PRO Beta Releases 3 October 8th, 2015 02:35 PM
Help with Linux mono probing path w.vuyk HS3 Plug-In Development 0 September 14th, 2014 04:42 AM
