15 years running HAI and now considering Homeseer to run legacy gear and the world of IoT devices. I have used OpenHab and loved it on a PI3 with some success but too difficult for me to configure.
Can someone let me know what all I would need to convert my system to HS? I have about 40 UPB switches, four room controllers, 350 lines of code, two newer thermostats, 3 ER temp sensors, and 1 relay set. I do have the newer OP2 panel. Old style consoles. 1 older LCD touchpad. Lots of apple stuff as well. Hot water heat with two zones.
Possible Plugins: Denon, Weather, but I could use some help here. Would you recommend other plugins. I have a Geovision DVR as well that would be nice to tie in.
The web sight and cool gear are somewhat over whelming for the un-initiated. They list the HAI stuff under Security but does that plugin do all the HAI gear? Not sure if my setup would run on a PI or not. For those of you long HAI users could you assist me with your experience? What's the right setup for my home configuration.
Oakguy
Oakguy
