To install, you need to install 3 pieces of software, links are below:
(The only update in this release is the client)
Keep in mind that this is still considered beta, so please make sure you backup your PC especially your HSTouch project files!
1) Android application for your Android device. This is an APK file that you must copy and run on your Android device. Your device must support side loading of applications. Most devices support this. The current application includes configurations for 480x800 and 480x854. If your device is a different screen size, the 480x800 will load but will not be sized correctly. Both configs are included in the latest designer so you can load and modify these configurations as needed.
2) HSTouch Server Plug-in. Version 1.0.0.25 or later of the HSTouch Server plug-in is required. The client will not connect without this plug-in. Download and run the plug-in installer on your HomeSeer system.
3) HSTouch Designer. Version 1.0.0.51 or later of the HSTouch Designer is required if you wish to create your own screens. The help file has been updated with Android information.
When the client is first run it will attempt to connect to our demo server. You can use this connection to verify operation. To change the connection, press the settings button (in the client app) and select the server connection you want to modify. The client supports up to 3 different servers. Modify the setting then press the back button to return to the cient, then press the settings button again, then select the server to connect to.
Changes from 0.0.4:
Project file changes:
* None
Client 0.0.6 changes:
* Authentication with server is now encrypted, requires version 1.0.0.25 or later of the HSTouch Server Plug-in
* Fixed screen background images stretching when told not to
* Password setting is now hidden
Server Plug-in 1.0.0.25 Changes
* Added support for decrypting authentication messages
Please post any issues to this thread.
Links:
(The client is for hardware running Android 2.1 or later. You can install the client on your Android device by pointing it's web browser to the APK file below)
Android Client APK file 0.0.6 for Android 2.1 or 2.2
HSTouch Server Plug-in 1.0.0.25
HSTouch Designer 1.0.0.52
If you are using a 1.5 or 1.6 Android client you can try this APK file. It randomly crashes on the Archos 7 tablet so it may not be stable on your hardware:
Android Client APL file 0.0.4 for Android 1.5 or 1.6
Changes from 0.0.4:
* None
Links:
