Originally posted by rjh
View Post
In setLevel() there is a mistake often scene in the Smartthings code, the value is reduced to being between 0..99. A value of 254 should for instance turn on the light and not adjust the value in the switch. Values like 100 and 253, have special meaning (this is off the top of my head, so I could be wrong/out of date).
The scenes stored in 1 and 2 in the switch are not activated from CentralScene (there is some discussion on what inventor intended). The Key Events for central scene are not fully described. The code account for event 0 and 1, but doesn't describe them out in events. Held is ignored. Does the Homeseer switch fully support the latest in Central Scene?
The dim preferences don't appear at first glance to protect LED bulbs (aka the one that are meant to dim which can on average go to 20% of standard voltage (I can't think of the right words to describe that at the moment)).
There is also a numbed of things missing in order to enable multiple controllers to play well with one another while receiving LifeLine messages.
Could you post the XML describing the switch? I would just buy a switch, but I want to know what I am getting
What new classes were added? what were removed? Does the switch still support up to five lifelines? What commands does the lifeline support?
