Hey guys !
I finally managed to get my insteon thermostat plugin devices to be discovered by the alexa homeseer skill ( misunderstood the update part where you have to delete the devices so there are recreated with the correct settings to be discovered ).
So now, after doing a discover device on alexa's UI, I got my 9 thermostats discovered but it only seems to discover the PROGRAM device of each tstats in the Insteon thermostat plugin. All devices of each thermostats are freshly created by the updated plugin and voice command is activated on each but Alexa does not discover the HEATING and COOLING devices.
I know it sees the tstats because when I ask it to set the heat or cool setpoint, it replies that it is not responding, to check network or power supply.
If I ask it to TURN ON LOUNGE THERMOSTAT, it says this device does not support this command which is normal I guess.
I tried to add "tell homeseer to" or "ask homeseer to" my voice commands but this works even less as it always replies : I'm not sure how I can help you with that...
Any idea what my problem is ? Thx !
No matter how I formulate my command, I cant get it
