An issue with using the MSCommLib control with Windows 8 has come up.
The fix is the following:
In your [hs root]\Data\BLRF\Registration folder there is a file called mscomm32.ocx
Copy it to the system32 folder under windows and also copy it to the %SystemRoot%\Syswow64 folder
Open a DOS window as an admin user
cd %SystemRoot%\Syswow64
regsvr32 mscomm32.ocx
*** Also make sure that UAC is disabled on your machine!!
This should solve the issue
