shill,
I see you place your PDF help file in the "standard" location off the HS3 tree:
/docs
Any chance you might consider moving or adding a copy to your html tree:
/html/skware/devicehistory
This is mostly for folks that try to access your help file via the HS3 web UI. It does not show up when you access HELP due to the web interface restriction to the /html tree - at least on HS3 running on Windows. Not sure how this is handled on the Linux version.
Also, I saw some other plugin authors maintain two copies of their PDFs as well... in the /html and /docs trees.
Thanks.
/docs
Thanks.
