Converting from HS Insteon plug in to MSandler ver
    Hello - my apologies if this has been addressed, but I wasn't having much luck with searches.
    I'm in the process of moving from the HS3 Insteon plug-in to the Sandler version. I've tried the various reset/reprogram buttons with in the app, but none of the HS3 Insteon defined devices are being recognized. Is there any way to just move these over to the new environment without having to delete/re-add and update all my events? (a really good answer would be yes!)
    Thanks in advance -
    Matt, nothing about the HS insteon plugin is compatible with mine.
    you will need to start fresh.
    delete all hs devices created by the other plugin.
    you will need to revise your events to use my plugin devices and triggers.
    I would also factory reset the PLM and insteon devices. the links that the other plugin writes may not be compatible either. do this before you start registering the devices with my plugin.
    Mark
    HS3 Pro 4.2.19.5
      OK - thanks. I guess I know what I'm doing this weekend!
