Thanks Dafunktyfunk - got the links working now.
I really like the plug in so far. I have two Trane thermostats and everything seems to running smoothly.
A couple of comments and suggestions:
-It has been been mentioned already but I too would like it if under operating it showed whether or not the unit was running (idle when the fan is off and heating/cooling when it's running.
-When I select either Auto or Aux mode in BLStat, the text box to input the set point goes away. For Auto, can it have both a heat and cool SP box to update both? Also, not sure what the Aux mode is intended for but it doesn't seem to change anything on my trane thermostat. Can it be used to but the stat into EHeat mode? If not, can an option be added for EHeat?
-In Schedule, can there be an option for duplicating or copying a day to other days? Also, with multiple thermostats, it might be helpful to be able to duplicate a day or an entire week from one thermostat's schedule to another.
-It might be useful to be able to save a schedule and then load a different one. For example, I could setup a normal schedule profile that I use most of the time and then create and load in a "guest" schedule or a "vacation" schedule with different times and set points. Then I could switch back and forth between schedules without having to re-enter everything.
-Building on the idea of multiple schedule profiles, it would be neat to be able to assign date specific information to them. For example, if I know in advance that I'm going to be away on 1/11, 1/14-15, 1/18-1/22, I could have the "vacation" profile automatically run on those dates without having to remember to change it back and forth each time.
Thanks again for the hard work!
