Originally posted by DJF3
View Post
Installing the IP THermostat plugin
Guest
Originally posted by ScottRennie View PostJust installed the Plug-in & get this error
ERROR: Unable to communicate with HONEYWELL. Are you sure the username and password are correct? --> Error in doPost:The remote server returned an error: (429) Too Many Requests.
The username & password is correct
Any ideas?
Cheers Rupp - all I can see is it's an Evohome controller - no model number. It's sold as evohome Controller (Generation 3).
(http://www.vesternet.com/evohome-wif...hermostat-pack)
It's a European / Uk system
I'll try that Plug-in.....
Thank you
For the other Plug-in, Shill's Honeywell WiFi Thermostat Plugin Beta Testing, I cant find the thermostat ID's - the mytotalconnectcomfort.com/en-GB website doesn't allow me to see any device IDs or manage my EvoHome using a browser on a PC.
Rien - Any ideas on how to make this plug-in work?
Regards
ScottLast edited by ScottRennie; September 1, 2015, 04:21 AM.
Originally posted by ScottRennie View PostFor the other Plug-in, Shill's Honeywell WiFi Thermostat Plugin Beta Testing, I cant find the thermostat ID's - the mytotalconnectcomfort.com/en-GB website doesn't allow me to see any device IDs or manage my EvoHome using a browser on a PC.
Regards
Scott
Scott
Originally posted by ScottRennie View PostRien?
Yes this should work, all tough some users have issues which I cannot reproduce in my environment (even with their account)
You can try the plugin for 30 days, so please give it a try!!Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Scott
Hi Rien
OK, plug in reports the following in the log
Sep-24 15:20:00 IPThermostat ERROR: Unable to communicate with HONEYWELL. Are you sure the username and password are correct? --> Error in doPost:The remote server returned an error: (429) Too Many Requests.
Sep-24 15:19:59 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:19:59 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:19:28 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:19:28 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:18:58 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:18:58 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:18:28 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:18:28 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:17:59 IPThermostat ERROR: Unable to communicate with HONEYWELL. Are you sure the username and password are correct? --> Error in doPost:The remote server returned an error: (429) Too Many Requests.
Sep-24 15:17:58 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:17:58 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:17:28 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:17:28 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:16:58 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:16:58 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:16:28 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-24 15:16:28 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-24 15:15:59 IPThermostat ERROR: Unable to communicate with HONEYWELL. Are you sure the username and password are correct? --> Error in doPost:The remote server returned an error: (429) Too Many Requests.
I know the username and password are correct...
What do you suggest?
Scott
Originally posted by Rien du Pre View PostPlease set your refresh interval to at least 5 minutes. The Honeywell server cannot handle too many requests.
Sep-26 10:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-26 10:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-26 10:23:25 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-26 10:23:25 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-26 09:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-26 09:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-26 09:23:25 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-26 09:23:25 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
Sep-26 08:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Parsing info
Sep-26 08:53:25 IPThermostat DEBUG1: PollHONEYWELLServer: Set credentials for HONEYWELL Server request.
With no devices being created.
Any ideas?
Scott
Aargh....
You have the same problem as some others, I'm sure that if I try it in my environment with your Honeywell credentials it works without any issues. I have seen this same problem in a couple of occasions.
The issue is that I cannot troubleshoot easy and tried already many workarounds, but no luck.
If I have more time I will surely dig deeper into this problem, but for now I 'm stockedRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
