PI Password
    PI Password
    I haven't done much with the PI since having set it all up last summer, c/w HS3, because it had been a bit of a pain for me to connect a display and keyboard/mouse to it.
    Recently got myself a HDMI to VGA converter and now have the PI connected to a KVM switch along with two other computers. Nice and painless except for the fact I seem to have forgotten both passwords I'd set up on the PI; passwords I'd thought would be rather simple at the time. Guess I'm too smart for my own good, or perhaps my memory really is failing.
    I'm a complete Linux noob. Is there any way to recover/reset both the root and user passwords without starting from scratch?
    OK. Remembered the root pw, but still need to reset the user password.
      Login as root, then type: passwd user
      Where user is the one you want to change.
      Sent from my SCH-R970X using Tapatalk
      HS4Pro on a Raspberry Pi4
      HSTouch Clients: 1 Android
        Personally I would add Webmin to the RPi2 as it is a nice overall web based management tool.
        It does fine with overall management of the hardware, updates et al (not related to HomeSeer 3 stuff).
        Install it; play with it. If you do not like it remove it.
        That aside I also wintel tools like putty (for SSH) and WinSCP today.
        You can also make a Homeseer web page an SSH console (which I use too).
        I have my RPi2 (s) not connected to any monitors today. (IE: the Zee-2 is in the attic and I am trying to break it).
        A recommendation relating to learning about the RPi2 / Linux is to start from scratch building a new RPi2-3 using the guides provided by Rob here and the Rasberry Pi folks. You will need to update Rob's RPi2 image as it is now over a year old.
        MicroSD cards are less than $10 these days. Purchase a couple of them. You cannot break the hardware.
        For Homeseer 3 you only need to add Mono to the build (which today I think it is included in the base).
          Well! That was too obvious. Thanks.
            No problem!
            I am installing Webmin on my Pi3 per Pete's suggestion. It does make all system management much easier. Basically, webmin can handle anything you can do at the command-line via web interface.
              Here is a quickie snapshot of Webmin on the Zee-2 and an SSH applet if you want to utilize SSH remotely within Homeseer.
              I utilize Webmin to keep the OS up to date.
