Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > GainTech Solutions Plug-Ins > GTS CPUXA Ocelot Plug-in (3P)
GTS CPUXA Ocelot Plug-in (3P) Discussion of GTS CPUXA Ocelot Plug-in
Old January 7th, 2017, 12:53 PM
thutchins thutchins is offline
Seer Plus
Connecting Leopard to SEL
I have an existing Leopard setup for years, would like to integrate it with my HS SEL system. I have a usb adapter that I use to access / program the Leopard. When I plug that usb cable into the SEL I see an new USB port available in the plug-in so I assume that is the correct port. But when I active the plugin / reboot the system then open the plugin / configure screen the firmware version etc is blank so I assume it is not seeing the Leopard connection.
Should this work with the SEL using a USB / serial adapter? Works great when I plug into a computer.
Old January 7th, 2017, 07:21 PM
bbowser's Avatar
bbowser bbowser is offline
Seer Plus
At this time I don't have an SEL for testing. I have had the plugin running on Debian7 and Centos7 with Ocelots. There may be an incompatibility with that specific version of Linux. Also, I have not tested the plugin with a Leopard but it should work. I don't know of any current users that have a Leopard running either.
You should be getting something like below in the beginning of the log when HS3 starts, can you post that here?
Feb-08 4:45:21 PM               Info                  Plugin GTS CPUXA has connected. IP:127.0.0.1:50068
Feb-08 4:45:21 PM	     	GTS CPUXA      	GTS CPUXA Plug-in, Version 3.4.0.17
Feb-08 4:45:21 PM	     	GTS CPUXA	      Initializing Ocelot on port COM3
Feb-08 4:45:22 PM	     	GTS CPUXA      	HSPI_GTS_CPUXA, Discovered Ocelot/Leopard -- Firmware/Rom Vers: 8.31/58 -- App Vers: 3.18
Feb-08 4:45:22 PM	     	GTS CPUXA	      Ocelot/Leopard has 1024 IR locations
Feb-08 4:45:24 PM	     	GTS CPUXA      	GTS CPUXA, Discovered Unit: SECU16 at address: 1
Feb-08 4:45:24 PM	     	GTS CPUXA	      GTS CPUXA, Discovered Unit: SECU16I at address: 2
Feb-08 4:45:24 PM	     	GTS CPUXA	      GTS CPUXA, Discovered Unit: SECU16-IR at address: 3
Feb-08 4:45:25 PM	     	Plug-In	            Finished initializing plug-in GTS CPUXA
Let me know
Bruce
Connect Leopard II to ELK M1G aboyce General M1 Discussion 0 November 7th, 2005 02:22 PM
IS the ADI/Leopard all that good ? aboyce ADI Ocelot 40 October 7th, 2005 07:33 PM
Leopard II uses, ideas? mycrobyte ADI Ocelot 0 October 5th, 2005 07:08 PM
How about this Leopard Users aboyce ADI Ocelot 9 August 4th, 2004 11:23 AM
Help with zapped Leopard phemelrijk ADI Ocelot 3 January 11th, 2002 09:10 AM
