Originally posted by Ltek
View Post
Easy Trigger Group
Originally posted by andyf View PostI also am using 3 different types of motion sensors and while their "motion" values are different, their "no motion" values are all zero. So you can test for "equal to 0" or "not equal to 0". This works well in my situation.
Sent from my SM-G950U using Tapatalk
Originally posted by andyf View PostIn my head I was picturing a section in the Plug-In Config where you created a Group Name and added the devices you wanted to be in that group. Then in the event you merely referenced the Group Name.
But I imagine that would be a lot more work and effort and the way it works now is great.
So, if the majority of you guys think it would be better to create group of devices from the config page, and then reference them by name in events, I will change it. Let me know.
Yes please
It would be very useful. For example to trigger an action if a window in a group changes or another group with the doors. Another group with room temperatures... a lot of applications.
It could replace a lot of scripts or events.
Definitely Yes, I'm waiting for this
Many thanks in advance.
Originally posted by spud View PostI thought creating the group on the fly while creating an event would be more convenient than having to create it in the Config page, but I see how using the same group in several different events could be useful, and it's not more difficult to implement.
Group 1:
Device A = On
Device B = Dim 10%
Group 2:
Device A = Dim 20%
Device B = Off
Sorry spud! The new update is unusable. The boxes used to add devices to the group are so small I can't identify the devices to add to the group. When you show location1 and location2 the actual device name becomes so truncated it's impossible to identify the actual device. Also, creating the group name seems to only allow alpha characters. "Occupancy.Sensors" was truncated to "OccupancySensors".
Originally posted by andyf View PostSorry spud! The new update is unusable. The boxes used to add devices to the group are so small I can't identify the devices to add to the group. When you show location1 and location2 the actual device name becomes so truncated it's impossible to identify the actual device. Also, creating the group name seems to only allow alpha characters. "Occupancy.Sensors" was truncated to "OccupancySensors".
the group name must be alphanum characters or '-' or '_'
I thought about that. When I was using location2 as the search criteria I abbreviated location2 for the devices I needed in the group. So Downstairs became KI. Downstairs became LR... etc. Now you were updating the plug-in to use the Config to create group name I reverted the location2 back to what it was. This caused the windows to be too small to identify the individual nodes. Is it possible to make the windows stretchable?
