upgrade Linux on hometrollerSEL ?
    I'm running HS3 Pro Edition 3.0.0.368 (Linux) on a SEL hometroller.
    The Linux kernel is very old, here's the result of a uname -a
    Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux
    Is there a way to upgrade the Linux kernel? There has to be a lot of security upgrades since this ancient kernel...
    Welcome to the Homeseer forum Dan.
    The SEL is running with 32bit Ubuntu 14.04 and Mono 3.28.
    If you want to run Ubuntu 16.XX or 17.XX 64bit it will need to be a total rebuild.
    I have updated 14.04 64 bit to 16.04 64 bit on a couple of machines. Did this with main Homeseer 3 Pro machine. It was a PITA.
    If you have many devices, events and triggers running with Mono 3.28 you will lose much of this stuff upgrading mono beyond 3.28.
    One user named Andrew (abwyatt) on the forum started to do that and purchased an Intel NUC.
    Not sure relating to Homeseer support or warranty on your SEL if you do this.
    Here running two Homeseer boxes at Ubuntu 16.04 64 bit and current release of Mono in 64bit mode.
    1- Pine64 2Gb computer
    ICS-Pine64:~# uname -a
    Linux ICS-Pine64 3.10.105-bsp-1.2-ayufan-77 #1 SMP PREEMPT Sun Jul 9 12:09:30 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
    ICS-Pine64:~# mono -V
    Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 21:20:16 UTC 2017)
    Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
    Architecture: arm64
    2 - Haswell based mITX iSeries 3 computer.
    ICS-HS3Pro:~# uname -a
    Linux ICS-HS3Pro 4.4.0-101-generic #124-Ubuntu SMP Fri Nov 10 18:29:59 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
    mono -V
    Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 20:37:08 UTC 2017)
    Architecture: amd64
