I installed a Trane XR524 and it appears to work properly with the web interface. Via a browser I can view status and change set points.
But I do not seem to be able to integrate controls via HS3 Touch. I also cannot seem to create a status widget to tell what state the thermostat is in.
I installed your plugin and it appears to properly sense the Trane thermostat. But I cannot see how this plugin helps with creating controls in HS3 Touch Designer. Your documentation suggests it does.
Can you push me in right direction please? Thanks
