SIP Connector - Features requests
This is a sticky topic.
    #76
    +1 for HS3.....Was great when I could announce the CLID via HSspekaer
    HS 2.2.0.11
      #77
      I think there is another HS3 SIP plugin in the updater.
      stipus
        #78
        At $50USD = $75 Australian Pesos....not today....:-)
        HS 2.2.0.11
          #79
          Same here... working 2 months on a SIP Plugin + countless hours of user support, to sell 20 plugins x $29.90 ... not today... !
          stipus
            #80
            Originally posted by SmarterControl View Post
            another vote here!
            Aren't you the author of the other sip plugin?
            _______________________________________________
            HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
            Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
            Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
              #81
              Hi Stipus,
              Looks like the other plugin (SCSIP) has been pulled from the HS updater, and is using a different lic. method from other HS plugins, which is holding me back from using this plugin.
              It sounds like you have no plans to migrate this plugin to HS3 - right?
              If so, would you consider posting the legacy code?
              An HS SIP plugin is my last key need to fully move to HS3...
              -Bob
                #82
                The code for the SIP Connector plugin is derived from the code of a commercial IVR I'm still selling to customers. You can understand that I cannot post the code.
                I have no immediate plan to port the SIP Connector to HS3, because such a plugin unfortunately requires too much time for user support.
                stipus
                  #83
                  OK, NP - figured I would ask.
                  -Bob
