This seems counter intuitive, but can you recommend a table top remote to control table lamps via HS? In several rooms I have table lamps managed by a HS lamp module with an event that allows them to be controlled via a HS wall switch (double-tap turns on the lamps). If sitting bear a lamp it would be nice to control it without getting up. Pre-HomeSeer I had table top touch switches that allowed you to turn lamps on, off and dim. Is there something similar that I can use with HS?
Table top remote for table lamps
ImperiHome running on a phone works well too, but not as convenient as voice or a dedicated remote.Mike____________________________________________________________ __________________
Guest
I use a couple Intermatic HA-07 remotes and they work well enough for me, just wish they weren't white.
https://www.amazon.com/gp/aw/d/B000B...rb_top?ie=UTF8
Additionally, google home works well, as does imperihome.
Guest
I had to add it to hs3 so that I could use it as a secondary controller. After that you copy the network to the Ha07, and then associate devices with each of the 6 (12 w/shift) channels
Thanks! On the Zee S2 I went to the ZWaveControllers page and selected Action of Send Network Information to another Controller, then followed your instructions of Hold Include for 5 seconds, then Press Ch1 Off and the Zee's network copied to the HA07. Then followed your remaining directions of Press/Hold On and Off buttons of a channel to Learn a Device, then Hold Include button while pressing Device's button. Worked great for first three devices. Finally, I don't have to talk to Alexa.
Guest
Awesome! Glad it worked out. As you might imagine, I grew tired of trying to remember how to do it each time so I just printed some labels from instructions I found on the HS forums.
