@Blade
Hi, I just bought HS3 and am testing BLGData as i prepare to migrate from Vera.
It seems i ran into a bug: The "Use End Time" check box on the Handler screen is not being saved or used.
a) The handler still runs at the start of the Google calendar event regardless of whether I checked the "Use End Time" check box or not when I setup the hander (in the HS3 log i can see the HS3 Event being run at the start of the google calendar Event time rather than at the end), and
b) when I return to the hander to edit it the check box does not display on the screen at all. Perhaps it is not being saved?
Please let me know if there is anything I can do to help track this down. Thanks!
I do not see any errors in the log (Debug Logging is enabled in the plugin):
System info:
-Michael
May-21 3:53:51 PM BLGData start BLGData plug-in has been initialized May-21 3:53:50 PM BLGData start No notifications have been assigned to BLGData! May-21 3:53:50 PM BLGData start Handlers have been loaded. May-21 3:53:50 PM BLGData start Users have been loaded. May-21 3:53:50 PM BLGData start BLGData Debug Logging is Enabled! May-21 3:53:50 PM BLGData start Loaded configuration successfully May-21 3:53:50 PM BLGData start BLGData version is: 2.0.33.0
Current Date/Time: 5/21/2017 4:09:20 PM HomeSeer Version: HS3 Pro Edition 3.0.0.318 Operating System: Microsoft Windows 7 Enterprise - Work Station System Uptime: 0 Days 0 Hours 58 Minutes 5 Seconds IP Address: 192.168.1.141 Number of Devices: 144 Number of Events: 8 Available Threads: 200 Enabled Plug-Ins 3.0.0.14: Autelis 2.0.33.0: BLGData 2.0.35.0: BLLAN 3.0.0.16: Ecobee 5.0.0.58: Global Cache Pro 3.6.5.0: Harmony Hub 3.0.0.68: HSTouch Server 1.0.17123.357: MyQ 3.0.0.21: Sonos 3.0.0.63: weatherXML 3.0.1.87: Z-Wave
