The door/window sensors I have have never been completely reliable. I have sensors by Aeotec and I have a Ingersoll Rand sensor. They were _more_ reliable under HS2 than HS3 hence posting under the plug-in.
As an engineer, I'm confused. Why would a Z-wave sensor _ever_ not report an open window (or closed) if the protocol has handshaking? I have sensors 5 feet from a repeating module and I'm missing window openings about half the time. That window's sensor has been replaced 3 times with two different brands and fresh batteries inserted. Same deal.
So questions:
1) Any way to extend the retries or timeout for a particular sensor with regard to z-wave controller? (Repeater already nearby.)
2) I have polling turned _on_ and wakeup set at 50 minutes ... why is Dev Mgr reporting an update like every 24 hours -- if that?
3) Any brands/models of door sensors that are for more serious / commercial applications?
4) Is Z-wave, like X-10, just inherently unsuitable for this task?
Thanks for any inputs!
Tahl
Current Date/Time: 9/19/2017 1:48:42 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.357
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 9 Days 21 Hours 6 Minutes 13 Seconds
IP Address: 192.168.168.11
Number of Devices: 190
Number of Events: 37
Available Threads: 1200
Enabled Plug-Ins
3.0.0.29: ADIO-100
3.0.6.22: Insteon
3.0.1.130: Z-Wave
So questions:
Tahl
Enabled Plug-Ins
3.0.0.29: ADIO-100
3.0.6.22: Insteon
3.0.1.130: Z-Wave
