New Error _ Confused
    HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
    BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
    DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
    That is strange - have u tried rolling back HS3 to see if that is the issue
    I am also running .368 but I do not have BLRadar running yet. I am having major memory issues with .368. Mine crashes at least once a day.
    Turn on debug logging and then run some UDMC code, then turn off debug logging and attach the debug log so I can see what is going on
    Cheers,
    Bob
      not yet on the rollback, today
      attached is debug log.....
      code is.....
      hs.PluginFunction("BLRadar", "", "ControlDevice", New Object(){"q54","on",0})
      thanks.
      D
        According to the log it ran the UDMC code
        I will test it tonight on my system
        Cheers,
        Bob
          Houston......
          So i looked more closely at the log and the code....then the devices....All the udmc code says switch on/off device code e.g. c15 ...but all my device codes have been reset to null.
          Blradar silently fails, but more importantly where did my device codes go.....
            Just the device codes for the sensors are missing? That is very strange.
            Cheers,
            Bob
              Yes indeed just the device codes, everything else behaving normally
                The device codes in HS3 itself or just in BLRadar?
                Can you attach your hspi_BLRadar.ini file zipped
                Cheers,
                Bob
                  Device codes in hs3, onceI reenter them, it works fine.....
