Way2Call Pro/Standard?
    My Way2Call (HD00USGR02) standard device started giving me trouble answering calls so I thought the easiest & fastest way to get it back up and running was to buy another so I ebayed a Pro model (HD00PRGR01). That one does not work at all. The 02 will at least allow calls to pass through and ring normally, but the Prgr01 will not. I am wondering if the drivers, usb, power, etc are really plug compatible between the two units? Anyone have experience with the two?
    The USGR02 had worked well for several years, then the USB starts to disconnect after HS3 has been up for a couple hours. It works fine up until the USB disconnects, and then of course will not reconnect until I restart HS3. Suggestions, anyone?
    Gary
    Try connecting a ground wire to the W2C box. That seemed to work a while ago.
      I saw posts suggesting that, but they seemed to be in relation to getting the callerID to pass through How would I go about grounding the W2C box?
      Gary
        Yeah here never had a problem but did read of HS folks doing this.
        I would suppose that you just connect a ground wire to the metal chassis inside of the plastic case a and bit exposed in the back of the unit. Easiest would be just to crimp a wire between the plastic and the metal.
        Phone wiring here has always been the same.
        Copper-VOIP-backup go to a Leviton telephone patch panel with an RJ31X. (kind of a hybrid mix today of one copper, two VOIP and one backup cellular phone line).
        And these connections go to
        One analog multiline telephone and one Panasonic wireless multiline base unit.
        There is an earth ground to two Leviton cans, alarm panel, switch in alarm panel, et al.
        First build involved an earth ground as most important. Electrical fuse panel has an earth ground going to the ingress of the copper water pipe feeding the house here.
          Pete,
          Hmm Not sure about the "metal chassis" connection, all I really see is the plastic case and the circuit board (see below). You think there a place to solder a wire to the circuit board? I am afraid I am still not clear on where the other end of such a wire would go. My home is grounded, like you say, the electrical circuit breaker panel has a ground rod, so I would assume one could connect the ground to the ground prong of any available 3 prong socket?
          On another note, my original W2C device (USGR02), causes HSPhone to log these two messages every 4 minutes.
          Oct-10 12:30:00 PM Phone Line 1 Internal answer is disabled, ignoring off-hook
          Oct-10 12:30:03 PM HSPhone
          Muting rings enabled
          Never understood why, but it does light up my answer machine for a second or two, indicating an off-hook condition. Have any thoughts?
          Anyone?
          Gary
            Hello Gary. I have not seen the message above.
            I am still utilizing the original W2C boxes purchased in the early 2000's.
            I also have a serial W2C box which works except for the voice part.
            Are you using copper or VOIP for your W2C box?
            Here I had issues with 2nd Ooma line (using Linx?). Ooma primary line has been fine.
            I would use the metal housing for the USB port as a ground.
              Good to know they last that long. I have/had been using the USGR02 for a couple years, but it too was bought used off ebay, so who knows what had happened to it before I installed it. I have always suspected something was a little off, because of the off-hooks.
              VOIP. Hope they didn't change something that started all my problems.
              Solder a wire to the USB housing and run to a socket ground outlet? Am I understanding that rigging correctly?
              Gary
