SO - how many upgrades did HST sell?
Upgrading HomeSeer 2 to HomeSeer Pro - First cut
Originally posted by Bill Brower View PostSO - how many upgrades did HST sell?
It was a good marketing move, do you not think? At this time of recession it brought coppers into the account.
An even better one if they are planning to go 100% Pro, and perhaps release a new version which is not an upgrade.sigpic
Upgrade took 5 minutes and no hitches.
THANK YOU FOR PROVIDING AN UPDATER AND
PROCEDURE THAT WORKED FLAWLESSLY!!!Best regards,
-Mark-
HSPro reboots computer every 2 minutes
I just upgraded from HS2 to HSPro. I downloaded and installed HSPro. I started HSPro and downloaded all the plugins that I need. Restarted HSPro and copied over my Config, Scripts, and data folder. Copied over my db. Restarted HSPro and my computer restarts after 2 minutes. After the computer reboots, I do not start HSPro, the computer reboots. I remove HSPro ,restart the computer, and start HS2. The computer is stable. What gives? Running XPSP3 with 2GB RAM.
Update:
After installing HSPro onto another system, I noticed the addition of HSSentry. Here is the log of the first computer:
12/10/2009 10:01:43 AM:HomeSeer 2 Sentry Service Started
12/10/2009 10:15:42 AM:HomeSeer 2 Sentry Service Started
12/10/2009 10:20:52 AM:HomeSeer 2 Sentry Service Started
12/10/2009 10:34:16 AM:HomeSeer 2 Sentry Service Started
12/10/2009 10:34:37 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:34:58 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:35:19 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:35:40 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:36:01 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:36:22 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:36:42 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:36:42 AM:Cannot access HomeSeer, shutting down system and re-starting...
12/10/2009 10:41:10 AM:HomeSeer 2 Sentry Service Started
12/10/2009 10:41:31 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:41:52 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:42:13 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:42:34 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:42:55 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:43:16 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:43:37 AM:Error accessing web server: Unable to connect to the remote server
12/10/2009 10:43:37 AM:Cannot access HomeSeer, shutting down system and re-starting...
12/10/2009 10:59:00 AM:HomeSeer 2 Sentry Service Started
It did not only restarted HSPro but the entire computer!
Originally posted by TotalVoice View Post... Restarted HSPro and my computer restarts after 2 minutes. ...
http://board.homeseer.com/showthread...ghlight=sentry
Originally posted by rjh View PostNote also that HSSentry was using "localhost". On some computers, localhost is not resolving to the local computer. The latest update (2.3.0.129 and later) have a new HSSentry that uses the computers actual IP address. You may need this new version.
The reason being, I have 4 IP addresses on my HSPRO XP machine. "about HS" shows all four, but picks the wrong one for the HS address. It should pick the LAN ethernet interface address, but usually picks either one of the VMware interfaces (HSPRO NOT running in VMWare) or bluetooth network interface.
I am concerned that HSSentry may not get it's pings back if HS PRO determines and uses the non-LAN ethernet a IP address.
Being able to set it would cover all bases.
Phil
I added an INI setting:
SentryIP
Set this to the IP address you want the Sentry to check. This change will be in 2.3.0.136 or later updaters.
I also now write the IP its using the sentry log file so you can check which IP its using.
-Rich
Originally posted by psampson View PostRich, could you possibly make the IP address a settable parameter in HSSentry?
Phil
Originally posted by rjh View PostI added an INI setting:
SentryIP
-Rich
I was wondering if there might be a secondary way for testing HS is alive in addition to the web server because very occassionally my HSPRO .86 will have a "sorry HSPRO needs to close" pop-up widow and HSsentry does not restart the system as though it is getting a response from HSPRO web server even though events seem to have stopped processing.
best regards,
Phil
So I'm about to upgrade my HS 2.3.0.52 to HSPro. Seems like there were a few methods floating around on the process of upgrading. Can someone give me guidance on the best way to upgrade the current version I am on? (2.3.0.52). I'd like to stay with this version when I upgrade to HSPRO. Any insight or pitfalls to watch for????
Is the OP the most current method of upgrading to HSPRO??
Ok the hspro updater worked great. HSPRO is not yet registered (i have 26 days left)
However i need to roll back to my old nonpro version!!! HOW do i do this????
Reason: I am getting a HS troller for a rental we have and i want to use the HSPRO i already paid for on there special they had last month. I had installed this version of HSPRO on my old pc here at home but it is not yet registered.
I don't think rolling back is hard i just don't know how. I went to Homeseer updates and Pro is the only choice now.
Thanks DJ
P.S. Of course if they gave me the same special they had last month on my new troller i would take that LOL
