Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Closed Thread
Old May 26th, 2012, 09:27 PM
mnsandler's Avatar
Insteon Overlord
Getting Started with Insteon and Homeseer
Recommendations for Getting Started with Insteon and Homeseer
You need the following:
- an Insteon controller such as the PLM 2413U (usb), 2413S (serial), or the newer Insteon Hub. I recommend the 2413S as it is more reliable. The USB dongle (2448A7-no longer available) was a good choice if your HS server is centrally located in your house and you don't need X10 capabilities.
- the new insteon hub (which is a network device) is a supported controller in v1.8 or later
- either a Singalinc (2406H) or a pair of dual-band devices (one installed on each leg/phase) of your electrical system. a pair of Access Points (2443) work as well.
- the Insteon PLM plugin
Prerequisites for the Insteon Hub:
you must to get the hub online and accessible locally via a browser; for example http://192.168.1.80:25105/network.htm. i would suggest a static ip address for the hub.
i believe the latest hubs come with an admin pswd that is printed on the bottom, so you may need to login with these creds. If all this works then you can proceed
This procedure is for HS2/HS3:
Here are the basics for getting started using a Smarthome PLM based interface and Homeseer:
1. Go to the HS Updater and install the following plugin: Insteon PLM Plug-In By Mark Sandler
Note: if you downloaded the plugin from the forum, shutdown HS, copy the hspi_insteon.dll (and other dlls) to your homeseer. For HS2 copy the insteon.lf file to the config folder and continue with step 3 below. The HS3 plugin should be installed from the Updater.
2. Shutdown HS
3. If you have a 2412u, 2413u or 2448A7T, then download and install the latest ftdi chipset drivers. this driver will provide the virtual com port that the plugin needs
http://www.ftdichip.com/Drivers/VCP.htm
installation instructions: http://www.ftdichip.com/Support/Docu...tallGuides.htm
Drivers are not required for the 2412s or 2413s or the Insteon Hub.
4. HS2: Restart HS and goto the HS setup/interface page, and Enable the IO Interface. If you use X10, enable that interface as well.
    HS3: Restart HS, go to the Manage/Plugin page and enable the plugin. Enable X10 on the plugin config page if necessary.
5. Goto the plugin config page (use the Insteon link on the previous page) and set the port: COM1, COM2, etc, or for the Hub enter the local IP address:Port# (eg 192.168.1.80:25105). You will also need to enter a username & password when using the hub. This is not the Smarthome Connect username & password
Note: for Linux (or Linux based devices like the HomeTroller Zee series) and OSX installations use something like the following for the Port name:
/dev/ttyS0 is COM1
/dev/ttyS1 is COM2
/dev/ttyUSB0 is USB (start here for OSX)
6. Restart HS again and watch for a successful connection from the plugin to the Interface.
7. Use the plugin Manage Devices page to start adding devices, etc.     Use the Add a New Insteon Device button. Enter the Insteon ID and location and name to register a device.
8. See the Documentation Post in this forum for details of each field or feature of the plugin.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Closed Thread
HTML code is On
