Go Back   HomeSeer Message Board > Thermostat / HVAC Plug-ins > Thermostat / HVAC Discussion
Old February 25th, 2016, 08:24 AM
mattm55 mattm55 is offline
Venstar Thermostat Plugin for HS3
What:
~Venstar Thermostat Plugin for HS3.
Why:
~A need for a plugin under HS3 for new Venstar thermostats. (I am not aware of a current HS3 plugin available).
I started this thread to document the progress of the Venstar Thermostat plugin for HS3. Once I have something working I will post a beta version for anyone wanting to try it out. I currently have the Venstar T7900 thermostat to use for testing but if anyone is interested in testing using a different model, I'll be open to making it compatible (as necessary).
Beta Release:
~TBD
Stable Release:
~TBD
Progress:
2016-02-25: I have the Venstar T7900 installed and connected to Skyport cloud. I had some trouble as my WiFi wouldn't show connection in list but my router listed it (by MAC). I opened up TCP ports 9000-9002 & 41414 as directed and it connected to Skyport. I also turned on API in thermostat for plugin development.
Thanks, Matt
HS: 3.x
HW: Insteon PLM 2412U, RFXCom, Concord Ultra w/AM, Brultech GEM, Brultech Dashbox, ELK-930, Venstar tStat T7900
3P-Plugins: GE Concord HS3, MS_Insteon HS3, UltraCID HS3, RFXCOM HS3, Venstar tStat HS3
3P-Plugins Admin: GE Concord HS3, Venstar tStat HS3 (beta)
Scripts: n/a
Server: Win8 (64bit), Intel i5-4670 3.4Ghz, Asus Z87i MB, 16GB RAM, 256GB SSD/1TB SATA
Old February 26th, 2016, 12:24 AM
Jon19 Jon19 is offline
My model
I have the T5900. I have the sky port wifi module as well. I would love to try a beta.
Thanks Jon
QUOTE=mattm55;1230744]What:
Why:
Beta Release:
~TBD
Stable Release:
~TBD
Progress:
Thanks, Matt[/QUOTE]
Old March 22nd, 2016, 01:43 PM
daviddc daviddc is offline
Viewer
Venstar vs Honeywell
Matt,
I really appreciate the effort you are making. I am totally new to Homeseer, but technically capable and now committed to the platform. I have a couple of questions that I am hoping you can help with:
- Is or will your Venstar plugin be as robust as the existing support for Honeywell? I am trying to decide between Honeywell and Venstar. I love the idea that the api is open but also wondering if that makes the Venstar the best choice.
- Do you recommend I get a Windows or Linux based Homeseer PRO?
David
Old March 29th, 2016, 06:45 AM
Originally Posted by daviddc View Post
Matt,
David
Great to hear. I got sidetracked for the moment with an Insteon issue but will back on the Venstar development shortly. Once I have something, even simple, I will put it out for testing.
Well, that decision is ultimately up to you. I had a Honeywell (Honeywell TH9320WF5003 Wi-Fi 9000 Color Touchscreen Thermostat) and liked it very much. Actually have it in a box as a backup of sorts. I might auction it at a later date. I didn't like 2 things about the Honeywell which made me switch to the Venstar.
1. No open API. There is now a HS plugin but if Honeywell changes their access, etc... it breaks the plugin. Support looks good on it so I wouldn't hesitate there. Also, it is ready to go now.
2. The Honeywell has a loud clicking when cycling on/off. With the tStat near where we sit, it was, annoying.
So, as robust. My goal is to be able to control the tStat and get as many features available to HS as I can. Then I want to mirror the stats to a db so there is historical data much like their Skycloud. So yes, I would say it will be as robust as the Honeywell. Now, I do have other projects going so if your looking for something immediate, go with the Honeywell.
[/QUOTE]
Ah, that would be your choice. I run off of Windows so I can test on that platform. I don't have a Linux setup for HS. That shouldn't discourage you as if your good with Linux, then go for it. Heck, with the RaspPI3 out, you might have a nice easy system build. That would be my route to setup as a test environment.
-Matt
Old June 4th, 2016, 02:56 PM
cadillackid's Avatar
cadillackid cadillackid is offline
I have a few venstar tstats and would love to be able to use them natively with Homeseer!
-Christopher
PerfecTemp - the Most advanced HVAC system I've ever Built - and its in my House
Old June 6th, 2016, 06:07 AM
-Christopher
OK, great to hear. When I have something for a beta, I'll post back.
Thanks, Matt
Old June 27th, 2016, 02:35 PM
LxMeister LxMeister is offline
Following.
Have a Venstar thermostat that came with my new house and I would love to integrate with my HS3 install!
Thanks in advance!
Old June 28th, 2016, 06:24 AM
Originally Posted by LxMeister View Post
Following.
Thanks in advance!
That's great to hear. Mine has been working great. As always, I got sidetracked doing an (urgent request) race scoring program for our group but will get back on it when done.
Thanks, Matt
Old August 10th, 2016, 04:38 PM
DomIII DomIII is offline
Add me to the Venstar list.
Like the look of the Tstat. Hopefully the plugin will be compatible with the T7850 too.
Thanks for you work.
Old August 11th, 2016, 06:05 AM
Will do.
This wlll be a winter project for me as I have been pulled off to develop a sim racing scoring system. That is almost complete and will resume this Venstar plugin.
I will try to incorporate as many versions of Venstar tStats as I can as long as we get good feedback from users. I like my tStat over the Honeywell I had in it's place.
Matt
Old November 25th, 2016, 10:03 PM
slbuck's Avatar
slbuck slbuck is offline
Venstar Voyager series
I'm looking at getting the T3900 which looks to also support the local API. I'm not concerned with a color or touch screen, so the voyage series looks pretty good. If I went with the wi-fi key in order to connect with Skyport, I should be able to have local API control and integration with Homeseer.
How's this plugin coming along and will you support the Voyager line of thermostats from Venstar?
Old November 25th, 2016, 11:13 PM
Amigo Amigo is offline
I am also interested for a venstar plugin.
For the voyager series, the latest I have heard is that a z-wave key has gone in production and will be at the distributors in 2-3 months.
Old November 28th, 2016, 08:59 AM
This plugin is next on my list of "to-do's".
I don't know about the T3900 or other series but if the same API is used then we might benefit from compatibility or incompatibility? Time will tell. So all I can say is to install the plugin (once available) and test and provide feedback.
Matt
Old February 17th, 2017, 12:32 AM
Venstar plugin
Hi Matt,
Just wanted to follow up to see if you had any further progress on the plugin for the Venstar?
Jon
Old February 17th, 2017, 07:16 AM
Hello,
Unfortunately, I don't have the time now to devote to this project. I may pick it back up when things quiet down. If someone else wants to provide the "pi", that's fine.
Thanks.
Old February 17th, 2017, 11:26 AM
Originally Posted by mattm55 View Post
Hello,
Thanks.
I am so very sad about about. I was really looking forward to this plugin. Thank you for your thoughts on getting it going! Hopefully you can find some time down the road as this would be useful to a number of us. I wish I had the know how to make a PI, as I would give it a shot, but it's way outside my skill level, LOL.
Old February 17th, 2017, 01:35 PM
Well, shucks. I was looking forward to this too! But I understand being too busy, believe me. Hopefully you are able to find some time eventually.
Thanks anyway!
Old October 30th, 2017, 03:28 PM
is this project dead? I havent worked on my HA system much lately.. its been ROCK STABLE, but I do need to get my venstars incorporated instead of my RCS...
-Christopher
Old October 31st, 2017, 06:13 AM
-Christopher
Actually, I'm just coming off a large project at work and should have free time over the next few months to pick this project back up. I want to get my Venstar integrated into HS as well ;o)
Old December 2nd, 2017, 12:36 PM
Looking forward to this
Hello! Now that my Christmas lights to music show is up and running , I want to get back to finishing up my HS system and the Venstar was the last component I needed to add to my system. Please keep us posted on the progress. :-)
HTML code is On
Script to control Venstar T5800 thermostat jwshome2 Thermostat / HVAC Discussion 8 December 17th, 2015 01:22 AM
Set up Venstar, Sage Thermostat Plugin in HS2 dmelnyk Sage Insteon Thermostat Plug-in 2 February 28th, 2012 12:33 AM
Does Venstar Thermostat Insteon work with Homeseer 2? dmelnyk Lighting & Primary Technology Discussion 3 February 3rd, 2012 09:34 PM
Controlling Venstar T1800 Thermostat with Homeseer skozin Insteon Plug-in (Mark Sandler) 4 January 27th, 2010 03:45 PM
Insteon Thermostat by Venstar paulbernot Insteon Plug-in (Mark Sandler) 2 September 1st, 2008 02:53 PM
