Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
  #61
Old September 19th, 2017, 11:28 PM
Burrington Burrington is offline
No problems on my end.
  #62
Old September 28th, 2017, 01:16 PM
vball61 vball61 is offline
Originally Posted by mnsandler View Post
Possibly. give it a go and let me know
I'm still having an issue with the Beta where my IOLinc sensor is incorrectly being reported as changing state. It's only happening once every 2-3 days, and I've attached a log of one incident, below.
For comparison, I NEVER had this occur prior to installing the Beta (and I've been using the Insteon plugin since the end of February).
The issue with the Beta where an incorrect Unknown value = 0 was being reported on loss of comm. (causing the system to think that the garage door had been opened) occurred 3-4 times per day until it was fixed (thanks, for that).
Sep-27 11:01:28 PM Event Event Trigger "Notifications Unsecure System Status"
Sep-27 11:01:28 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:100 Old Value:100, New Status:3 New Value:0
Sep-27 11:01:28 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
Sep-27 11:01:28 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
Sep-27 11:01:28 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
Sep-27 11:01:28 PM Insteon Received STX 0x50 (Raw Insteon Rec):1F C3 AA 2A 01 80 26 00 00
Sep-27 11:01:28 PM Insteon ..Got RF PLM Response 02 62 1F C3 AA 0A 19 01 06
Sep-27 11:01:28 PM Insteon Saved ini file. msecs=14
Sep-27 11:01:28 PM Insteon Sending command 02 62 1F C3 AA 0A 19 01 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Sep-27 11:01:28 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
Sep-27 11:01:28 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
Sep-27 11:01:25 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
Sep-27 11:01:25 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
Sep-27 11:01:25 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 27 00 00
Sep-27 11:01:25 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
Sep-27 11:01:25 PM Insteon Received STX 0x50 (Raw Insteon Rec):1F C3 AA 2A 01 80 27 00 00
Sep-27 11:01:24 PM Insteon ..Got RF PLM Response 02 62 1F C3 AA 0A 19 00 06
Sep-27 11:01:24 PM Insteon Sending command 02 62 1F C3 AA 0A 19 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Sep-27 11:01:24 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
  #63
Old September 28th, 2017, 03:35 PM
mnsandler's Avatar
Insteon Overlord
Have you tried the latest beta. I changed the unknown value to -1
  #64
Old September 29th, 2017, 04:09 PM
Yes, I'm now using 3.0.6.22. That unknown value issue looks like it's been fixed (thanks). This appears to be different - an ack from the I/O Linc is received, but the state of the sensor is toggled. On the next polling cycle (I poll this device every minute), the sensor is toggled back to the correct state.
This hadn't happened with 3.0.6.0 since February. I only started to experience these false sensor readings when I switched to the beta.
  #65
Old September 29th, 2017, 06:28 PM
mnsandler's Avatar
Insteon Overlord
do you have a detailed log snippet that shows the input sensor changing status back and forth after a second polling
  #66
Old October 4th, 2017, 08:18 AM
I've expanded the earlier snippet I posted (filtered for device 1F.C3.AA), to show the value change on the next polling interval.
I was hoping to catch a new event, but ran into an issue with polling of the device becoming disabled. I'll put that in a new post.
Sep-27 11:02:44 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:0 Old Value:0, New Status:2 New Value:100
Sep-27 11:02:44 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
Sep-27 11:02:44 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
Sep-27 11:02:44 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
Sep-27 11:02:42 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
Sep-27 11:02:42 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
Sep-27 11:02:39 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
Sep-27 11:02:39 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
Sep-27 11:02:39 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
Sep-27 11:02:39 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
Sep-27 11:02:39 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
Sep-27 11:02:39 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
Sep-27 11:02:39 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/27/2017 11:01:28 PM. Polling interval of 1 min. reached, polling...
Sep-27 11:01:24 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
Sep-27 11:01:24 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/27/2017 11:00:14 PM. Polling interval of 1 min. reached, polling...
  #67
Old October 4th, 2017, 08:33 AM
I encountered another issue, where after a second unsuccessful polling attempt of my garage door I/O Linc, the value for the sensor (1F.C3.AA:1) was changed from 'Unknown' (-1) to 'Open' (0), and polling became disabled for that I/O Linc (polling interval set to 0). Is that intended behavior? I didn't realize that polling had been disabled until I reviewed the log last night.
Thanks.
Sep-29 1:59:42 PM Insteon Warning! Polling failed twice for device: Access Garage Door (1F.C3.AA)
Sep-29 1:59:42 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:-1 Old Value:-1, New Status:3 New Value:0
Sep-29 1:59:42 PM Insteon Did not get any status response from 1F.C3.AA after 5 tries. No change to database delta value.
Sep-29 1:59:42 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #5 failed.
Sep-29 1:59:39 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #4 failed.
Sep-29 1:59:35 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #3 failed.
Sep-29 1:59:31 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #2 failed.
Sep-29 1:59:28 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
Sep-29 1:59:24 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
Sep-29 1:59:24 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Input Sensor: Garage Door Status (1F.C3.AA)
Sep-29 1:59:21 PM Insteon Setting status and value for device 1F.C3.AA:2. Old status:0 Old Value:0, New Status:3 New Value:0
Sep-29 1:59:21 PM Insteon Database delta value of 0 for device 1F.C3.AA is current. No changes since last database update.
Sep-29 1:59:21 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
Sep-29 1:59:21 PM Insteon Database recently heard delta value for device 1F.C3.AA is current.
Sep-29 1:59:21 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
Sep-29 1:59:18 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
Sep-29 1:59:18 PM Insteon Requesting Insteon status (Polling) for device Access Garage Door Output Relay: Garage Door Control (1F.C3.AA)
Sep-29 1:59:18 PM Insteon Timed poll for Insteon device Access Garage Door (1F.C3.AA), Last contact 9/29/2017 1:58:12 PM. Polling interval of 1 min. reached, polling...
Sep-29 1:58:12 PM Insteon Setting status and value for device 1F.C3.AA:1. Old status:0 Old Value:0, New Status: Unknown New Value: -1
Sep-29 1:58:12 PM Insteon Did not get any status response from 1F.C3.AA after 5 tries. No change to database delta value.
Sep-29 1:58:12 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #5 failed.
Sep-29 1:58:09 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #4 failed.
Sep-29 1:58:05 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #3 failed.
Sep-29 1:58:02 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #2 failed.
Sep-29 1:57:58 PM Insteon Did not receive a response from Access Garage Door (1F.C3.AA). Try #1 failed.
Sep-29 1:57:55 PM Insteon Attempting to update the status for Access Garage Door (1F.C3.AA)
  #68
Old October 4th, 2017, 08:54 AM
mnsandler's Avatar
Insteon Overlord
This is not going to be easy.
The first poll of the sensor produced the following:
The second poll of the sensor produced the following:
these two responses would indicate a status change.
  #69
Old October 4th, 2017, 09:04 AM
mnsandler's Avatar
Insteon Overlord
Thanks.
I did add a feature that disables polling after two unsuccessful attempts. you can override the default below. Add the key/value to your ini and set to 0 to completely disable. Otherwise increase 2 to 5 for instance.
[Config]
FailedPollThreshold=2
  #70
Old October 4th, 2017, 09:23 AM
[Config]
Thanks for the info. I'll make that change. FWIW, I'd prefer an option to never disable polling, even on total loss of comm.. The comm. reliability for my garage door I/O Linc is only around 91% (detached garage, at the back of my yard), and I can see the potential for polling being disabled due to loss of power to the I/O Linc (circuit breaker trip, for example) without notification. Just my $0.02.
It appears that there is still an issue with the device value being changed from -1 to 0 on the second unsuccessful polling attempt.
  #71
Old October 4th, 2017, 09:28 AM
mnsandler's Avatar
Insteon Overlord
Originally Posted by mrceolla View Post
Hi Mark,
I've received my replacement Siren and there was no change the behavior I described above. Have you had a chance to look into that at all?
no, i'll take a look soon
  #72
Old October 4th, 2017, 10:00 AM
I agree. This appears to be the same issue reported by Burrington in another thread.
I've filtered my log to show only the ACKs around the false sensor setting (below). It looks like the I/O Linc sensor is being polled 3-5 seconds after the relay contact.
The incorrect ACK received at 'Sep-27 11:01:28 PM' also has a different 'Hops Left/Max Hops' value ($6) than the previous ACKs, so it doesn't appear that the plugin is using stale data.
Sep-27 11:05:18 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
Sep-27 11:05:14 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
Sep-27 11:03:58 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
Sep-27 11:03:54 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
Sep-27 11:00:14 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
Sep-27 11:00:10 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
Sep-27 10:59:02 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 27 00 01
Sep-27 10:58:58 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 00
Sep-27 10:57:44 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 2B 00 01
Sep-27 10:57:39 PM Insteon Received a Direct ACK from Access Garage Door (1F.C3.AA): 1F C3 AA 2A 01 80 26 00 00
  #73
Old October 4th, 2017, 04:05 PM
mnsandler's Avatar
Insteon Overlord
I think I finally found the issue. i'll post 3.0.6.23 to the beta section of the updater
  #74
Old October 5th, 2017, 06:12 PM
[Config]
I added "FailedPollThreshold=0" to the [Config] section of my Insteon.ini, but it gets deleted any time the .ini is updated for any reason. Any ideas?
  #75
Old October 5th, 2017, 07:28 PM
mnsandler's Avatar
Insteon Overlord
Shutdown plugin. Added key. Restart plugin
  #76
Old October 7th, 2017, 12:49 AM
MarkHargrove MarkHargrove is offline
Insteon Plugin Appears Broken in Linux v372
372 was just posted today and your Insteon plugin now appears to be broken. When trying to add a device tonight, for example, I'm seeing:
Oct 6 22:43:50 elms-hs3-01 mono[11784]: 10:43:50:3743:[Insteon]->***:Error in Background Update (DoJob #20): System.IndexOutOfRangeException: Index was outside the bounds of the array.
Oct 6 22:43:50 elms-hs3-01 mono[11784]: at Insteon.Support.BackgroundUpdate.DoJob () [0x00377] in <49c60a66e6bf4117b52caf2667891f5a>:0
Oct 6 22:43:50 elms-hs3-01 mono[11784]: 10:43:50:3797:[Insteon]->** An error occurred in this plug-in. The details have been written to the log file - /usr/local/homeseer/Config/Insteon Error Report.Log
Oct 6 22:43:50 elms-hs3-01 mono[11784]: 10:43:50:3839:[Insteon]->** To request help with this problem please post this log file to the forum along with a detailed description of what lead to this problem.
..in the log.
Also, curiously, a few of my devices that have been actively used for, well -- for years -- just disappeared. The 'add' operation above as to add them back. They're still in the Insteon Hub and behaving normally from there, but were just -- gone -- from the Insteon plugin device list. I have something on the order of 50-60 Insteon devices, so taking a complete inventory will take a day or two to see what might all be missing besides the four I've noticed.
Any idea what might be going on?
Mark Hargrove
Longmont, CO
  #77
Old October 7th, 2017, 01:08 PM
mnsandler's Avatar
Insteon Overlord
can you post the insteon error report.log file? I need to see the log entries before the error
  #78
Old October 23rd, 2017, 08:03 AM
Just a follow-up. Since updating to 3.0.6.23 over two weeks ago, I haven't had any instances of I/O Linc sensors incorrectly reported as changing state.
  #79
Old October 23rd, 2017, 08:19 AM
mnsandler's Avatar
Insteon Overlord
thanks for reporting back. we'll call this fixed for now.
  #80
Old December 29th, 2017, 12:16 PM
bburns bburns is offline
Download Plugin?
Where does one download the new version of the plugin?
HTML code is On
HS3 Insteon Plug-In Version 3.0.5.88 Beta (Win & Linux)..In Beta section of Updater mnsandler Insteon Plug-in (Mark Sandler) 102 November 15th, 2016 08:48 PM
HS3 Insteon Plug-In Version 3.0.5.9 Beta (Windows & Linux Compatible) mnsandler Insteon Plug-in (Mark Sandler) 40 December 8th, 2014 07:59 AM
HS2 Insteon PLM Plug-In Version 1.9.1 Beta mnsandler Insteon Plug-in (Mark Sandler) 156 November 10th, 2013 02:08 PM
Insteon PLM Plug-In Version 1.8.0.8 Beta mnsandler Insteon Plug-in (Mark Sandler) 27 February 1st, 2013 09:31 PM
Insteon PLM Plug-In Version 1.7.0.0 Beta mnsandler Insteon Plug-in (Mark Sandler) 130 June 30th, 2012 02:22 PM
