Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old December 15th, 2017, 02:58 PM
neutronspin neutronspin is offline
New User Question On Backups
Hello Mark...I am using your plugin and it works great. I have a question concerning backing up my devices in case my HS3 ZEE S2 Edition 3.0.0.368 (Linux) hub has failed. What would be the best way to make sure if my hub failed for some reason or the data file supporting my devices and setup information was lost? Please be kind...I am still on my learning curve. Any help appreciated.
Old December 15th, 2017, 03:29 PM
mnsandler's Avatar
Insteon Overlord
For my plugin you need to backup the config/Insteon.ini and homeseer.hsd files
I actually don't know how to download files from the Zee
There is a plugin blbackup you might check out.
I would check out the forum on the Zee and see what others are doing
Old December 17th, 2017, 03:22 PM
logbuilder logbuilder is offline
Mark,
When I do the normal HS3 backup of the config, does it also backup all the insteon stuff or do I need to do more?
Robert
Old December 24th, 2017, 10:50 PM
mnsandler's Avatar
Insteon Overlord
do a quick test, but i don't think so. i think the hs3 backup routine only backs up hs3 files not plugin files.
HTML code is On
Question from new to HS3 Pro user mm5300 HS3 / HS3PRO Discussion 11 May 25th, 2016 10:07 PM
New user - Question about trial and HouseLinc clarkes71 Insteon Plug-in (Mark Sandler) 3 June 14th, 2013 09:44 PM
New user with a first time setup question. RobCrisp UltraGCIR HSPI 5 February 10th, 2013 08:25 PM
Web User Password Question Kbevo HS2 / HSPRO 2 April 25th, 2011 06:13 PM
New User Question maliga SpeakEasy Plug-In 12 August 10th, 2004 08:36 AM
