Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old December 19th, 2017, 11:28 PM
leerobinson leerobinson is offline
Null reference error during startup
Occasionally I see this error in the Startup Log. The same error also occasionally occurs with the Restart Plugin.
12/19/2017 3:03:35 PM ~!~Z-Wave~!~Z-Net Z-Wave: .............................. FINISHED ..............................
12/19/2017 3:03:35 PM ~!~Z-Wave~!~Z-Net Z-Wave: ............................................................ ..........
12/19/2017 3:03:35 PM ~!~Error~!~Initializing plug-in(2): Insteon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
12/19/2017 3:03:35 PM ~!~Plug-In~!~Finished initializing plug-in Insteon
12/19/2017 3:03:36 PM ~!~HSTouch Server~!~Server started on port 10200
12/19/2017 3:03:36 PM ~!~Startup~!~HStouch server started, waiting for clients to connect.
12/19/2017 3:03:39 PM ~!~Z-Wave~!~***************************************************** **************************
12/19/2017 3:03:39 PM ~!~Z-Wave~!~ STARTUP COMPLETE: All configured interfaces were successfully initialized.
Old December 24th, 2017, 12:00 PM
mnsandler's Avatar
Insteon Overlord
did you get this resolved?
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old December 29th, 2017, 07:37 PM
Homeseer says the problem is with the Plugin
When I asked Homeseer about it, they said the problem was with the plugins. What is the next step?
The same error occurs with the Restart Plugin. The author added some additional diagnostic displays and they do not show errors in the Restart Plugin.
The error happened again today. It does not happen every day, only occasionally. I have the server reboot every day at 3:00 PM to reset and clear everything. I experienced reliability issues when I did not have the server reboot periodically.
Here is an excerpt from the startup log:
12/29/2017 3:03:51 PM ~!~Z-Wave~!~Z-Net Z-Wave: ............................................................ ..........
12/29/2017 3:03:51 PM ~!~Plug-In~!~Finished initializing plug-in Restart
12/29/2017 3:03:51 PM ~!~Info~!~Plugin Insteon has connected. IP:127.0.0.1:1207
12/29/2017 3:03:53 PM ~!~Z-Wave~!~***************************************************** **************************
12/29/2017 3:03:53 PM ~!~Z-Wave~!~ STARTUP COMPLETE: All configured interfaces were successfully initialized.
12/29/2017 3:03:54 PM ~!~Error~!~Initializing plug-in(2): Insteon Instance::Object reference not set to an instance of an object.STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
12/29/2017 3:03:54 PM ~!~Plug-In~!~Finished initializing plug-in Insteon
12/29/2017 3:03:54 PM ~!~HSTouch Server~!~Server started on port 10200
12/29/2017 3:03:54 PM ~!~Startup~!~HStouch server started, waiting for clients to connect.
12/29/2017 3:03:59 PM ~!~Web Server~!~Local IP address (subnet) is: 10.0.0.32 (255.255.255.0)
12/29/2017 3:03:59 PM ~!~Web Server~!~UPNP Discovery started
12/29/2017 3:03:59 PM ~!~Web Server~!~Web Server started on port 80
Old December 29th, 2017, 07:57 PM
mnsandler's Avatar
Insteon Overlord
can you verify the plugin version you are running, and the version of the insteon.dll file
please post here
Old December 29th, 2017, 08:06 PM
plugin version 3.0.6.0 Inteon.dll 1.0.6.0 11/28/2016
Old December 29th, 2017, 08:41 PM
mnsandler's Avatar
Insteon Overlord
can you disable all your other plugins and restart hs a few times and see if you get the error
Old December 29th, 2017, 08:52 PM
I disabled CM15A, Restart, and ZWAVE plugins, then restarted 3 times, no errors.
Old December 29th, 2017, 08:54 PM
I could do without the Restart plugin for several days and see if the error occurs again.
Old December 29th, 2017, 08:57 PM
mnsandler's Avatar
Insteon Overlord
After your test, Also try enabling other plugins one by one to see which one might be causing the problem for the others
Old December 29th, 2017, 10:15 PM
I disabled the other three plugins then enabled them one-by-one, restarting several times after each was enabled. No errors. Unfortunately, it is an intermittent error. I hate having them in my programs.
Old December 30th, 2017, 10:16 AM
mnsandler's Avatar
Insteon Overlord
Let me know what you find.
Tags
error, insteon, null reference, startup, startuplog
HTML code is On
Null reference? Uncle Michael Ecobee (3P) 5 February 18th, 2018 11:40 PM
Null object reference error in Startup Log leerobinson Restart Plug-in 26 January 28th, 2018 04:04 PM
Error trying to include or exclude - object is null mikee123 Z-NET 0 April 15th, 2017 04:52 PM
ERROR Array cannot be null baudi IFTTT (3P) 0 November 4th, 2016 06:50 PM
Buildpage Error Message: Error in LINEStatus: Value cannot be null simonog Jon00's plugins and scripts 5 January 26th, 2008 08:06 PM
