Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old January 1st, 2018, 06:50 PM
timmymac123 timmymac123 is offline
Seer Plus
Any idea what causes: "Port_DataReceived Error: Specified port is not open"
After restarting the homeseer service , then the laptop, I am getting this:
Repeated forever until the system is rebooted or the service is restarted.
The PLM works until that message starts, then homeseer is worthless. The messasges appear so fast and frequent, there is nothing to see.
Any ideas or help here?
thanks.
Old January 1st, 2018, 07:03 PM
mnsandler's Avatar
Insteon Overlord
can you tell me about your setup?
what OS are you using?
what plugin version are you running?
which PLM are you using (model and version), and how is it connected to the server?
the plm hardware version is on a sticker on the outside.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old January 1st, 2018, 07:11 PM
Seer Plus
Linux homeauto64 4.14.8-200.fc26.x86_64 #1 SMP Wed Dec 20 19:05:23 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Insteon Plugin: 3.0.6.23
HomeSeer Version: HS3 Standard Edition 3.0.0.393 (Linux)
Insteon 2413U (USB)
RF PLM contacted on /dev/ttyUSB0 with an Insteon address of 14.83.65 and firmware version 92
V1.0 0944
Anything else?
FWIW, I shut down the laptop, unplugged the PLM and then plugged it back in.
Before I unplugged it, the green LED on the PLM was bright and almost constant. After the power cycle, seems to be better.
Old January 1st, 2018, 07:27 PM
mnsandler's Avatar
Insteon Overlord
this issue is typically caused by noise on the powerline that actually interferes with the usb connection between the plm and server usb port.
fluorescent lights, or even a washing machine have been known to cause this.
there are special insteon triggers you can try to setup in events to restart the plugin when the "interface crashes"
if you can't find the source of the electrical noise, you can try the trigger.
newer V2.x PLMs seem less susceptible to this issue.
you can do some research in this forum regarding 'usb disconnect' where others have resolved this.
HTML code is On
DSC Plugin is crashing my Zee S2 - "AcceptCallback: Too many open files" bkazm HomeSeer DSC Plug-in 2 September 19th, 2016 12:32 PM
error - Conversion from string """" to type 'Integer' is not valid. Jakob.Sand JowiHue Plug-In 10 October 19th, 2015 04:07 PM
"WARNING" or "ERROR" in Log Triggering Events? BobSpen HomeSeer General Discussion Area 11 February 16th, 2007 04:07 PM
change status from "alert" to "open" cubedweller W800 RF Receiver (3P) 11 March 7th, 2005 10:21 AM
