Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old January 1st, 2018, 10:27 PM
kamishki kamishki is offline
PLM stopped connecting
I see a similar thread on this but my situation is a bit different...
PLM has been working find for a few years but today it stopped.
Repeating error in the log is
Port_DataReceived Error: Specified port is not open
What are some troubleshooting steps to perform and can I check to verify that the PLM is still working.
Running full Homeseer on a RPI2
Current Date/Time: 1/1/2018 9:21:07 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.377
Linux version: Linux rpi1 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 16 Minutes 1 Second
IP Address: 192.168.x.x
Number of Devices: 101
Number of Events: 65
Available Threads: 399
HSTouch Enabled:True
Event Threads:0
Event Trigger Eval Queue:0
Event Trigger Priority Eval Queue:0
Device Exec Queue:0
Plugin Callback Queue:0
HSTouch Event Queue:0
Email Send Queue:0
Enabled Plug-Ins
2.0.5.0: BLGarbage
2.0.35.0: BLLAN
3.0.1.130: Z-Wave
(Disabled when created this)
3.0.6.0: Insteon
Old January 2nd, 2018, 08:23 AM
mnsandler's Avatar
Insteon Overlord
please review the following thread
https://forums.homeseer.com/showthread.php?t=193104
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old January 2nd, 2018, 02:50 PM
I have reviewed the thread.
The setup has worked for over a year...never any interference or problem connecting. HS/RPI to USB PLM has been pretty much rock solid. I have powered own the RPI and unplugged the PLM to reset everything and during HS startup it immediately writes the same error to the log till I disable the plugin.
On the RPI if I run lsusb it does see a FTDI USB to Serial Interface (I guess the USB PLM is just a serial one with a USB to serial chip built in)...but HS still can't establish a connection.
Is there a way to reset (besides unplugging) the PLM or to do some other troubleshooting?
Old January 2nd, 2018, 04:07 PM
mnsandler's Avatar
Insteon Overlord
there are event actions to disable and enable the interface. have you tried these?
there is also a reset interface action, but this only works if the plugin can communicate with the plm.
you could try a manual factory reset and if the plugin can connect, the use the update interface database (from plugin config page) to rewrite the plm database.
Old January 2nd, 2018, 11:25 PM
Last option did the trick...did a factory reset, restarted the plug-in and it worked.
Old January 3rd, 2018, 06:22 AM
mnsandler's Avatar
Insteon Overlord
were you able to reprogram the plm as well?
Old January 3rd, 2018, 10:58 AM
Yes...it seemed run to completion with no errors. Is this type of thing indicative of a potential future failure or is this something that we can expect from time to time.
Old January 3rd, 2018, 11:21 AM
mnsandler's Avatar
Insteon Overlord
it could be a sign of failure for V1x units.
V2x units are typically more reliable
what hardware version is your PLM? its on a sticker on the unit
Old January 3rd, 2018, 10:52 PM
V1B 1318
Old January 4th, 2018, 10:12 AM
mnsandler's Avatar
Insteon Overlord
V1B 1318
yah, keep a log of these failures. it might be an indication that the V1 PLM is failing
HTML code is On
Suddenly stopped connecting gdarby stefxx Plug-Ins 9 December 18th, 2017 12:42 PM
Help with connecting chris.atl Caddx 1 June 23rd, 2017 10:39 AM
sorry but its just not connecting again S.Morris BLOnkyo 12 May 27th, 2014 05:56 AM
Connecting to net alireza44907 HomeSeer General Discussion Area 6 November 1st, 2013 01:45 PM
Elk - HS not connecting Madcodger Elk M1 Plug-In 4 January 28th, 2006 07:39 AM
