Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old January 3rd, 2018, 05:05 PM
Ditlow Ditlow is offline
HSControl KPL Button Scene Control
I'm running HS3 on Linux and Insteon Plugin version 3.0.6.23. 3.0.6.23 is the beta version but this was occurring on the non-beta also.
I have several KPLs in the installation, the KPL buttons are used to control nearby lights at various dim levels and ramp rates.
For Example:
Button C on the Kitchen KPL turns off the kitchen and island lights while it turns on the sink light at 5%.
Button D on the Kitchen KPL turns on the kitchen, island, and sink lights at 50%.
I have 'Sync linked responder devices' enabled.
The problem:
When I physically press the KPL button it does what I expect, diming or turning off the various lights.
When I turn on the KPL button from HomeSeer web or HSTouch, all of the lights the keypad controls, even if not controlled by that button, turn on to 100% in .1 seconds. This holds true even if the default ramp rates and brightness for the loads are different (80% .5 seconds)
It doesn't seem to matter if controlled by individual links or by the group.
Besides using events, is there anyway to get the HomeSeer Web/HSTouch KPL buttons to work properly? I don't really want to program the KPLs twice (once in HS once in the plugin).
Controlling the groups instead of the KPL give me trouble too, because if I change one of the lights brightness manually I have the KPL button turn off but the group doesn't update it's status. Using an even to update the group status then turns off the lights.
HomeSeer Version: HS3 Standard Edition 3.0.0.357
Linux version: Linux HomeSeer 3.16.0-4-amd64 #1 SMP Debian 3.16.51-3 (2017-12-13) x86_64 GNU/Linux System Uptime: 0 Days 19 Hours 48 Minutes 31 Seconds
IP Address: 10.10.100.249
Number of Devices: 86
Number of Events: 27
Available Threads: 399
Enabled Plug-Ins
2.0.38.0: BLLAN
2.0.22.0: BLOccupied
2.0.26.0: BLRing
3.0.0.6: HSZigBee
3.0.6.23: Insteon
3.0.0.76: weatherXML
Old January 3rd, 2018, 08:37 PM
mnsandler's Avatar
mnsandler mnsandler is online now
Insteon Overlord
have you tried creating a Group in the plugin? Set the KPL btn as the controller and set the desired on-levels and ramp rates for the devices.
then you can control the kpl btn from hs, the plugin should set the other devices correctly
More:
the plugin doesn't update the group device status based on any changes from the participants. there is no way to know what should happen in every scenario.
default on-levels and ramp rates are not used with insteon links. Links have their own settings. you can set these when you build the links.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old January 3rd, 2018, 09:39 PM
I have tried using groups, even with the group using the HS KPL button turns on all devices controlled by the keypad at 100%, even devices that aren't controlled by the keypad button I turned on.
Understood on the other items.
Old January 3rd, 2018, 09:48 PM
mnsandler's Avatar
Insteon Overlord
for one of the devices that is controlled by the kpl and turning on incorrectly at 100% can you copy the link data from the [device x] section of the insteon.ini
i would also like to see the link from the UI for the device
Old January 3rd, 2018, 11:36 PM
Sure.
This is the 'Kitchen Sink Light'
Button D on the 'KPL Living Room' should set the Sink light to 5% and turn other lights off.
Pressing the physical button does just that. Clicking the button in HS turns all the lights controlled by the KPL on at 100%
[Device 11]
DatabaseDelta=1
DeviceID=48.08.31
DeviceLocation=Kitchen
DeviceName=Sink Light
DeviceType=0120
EEValues=LEDBrightness=31,DefaultOnLevel=255,DefaultRampRate =28,OpFlags1=0
FailedInteractions=6
FirmwareVer=45
HopData=71,71,0,0
LastContact=1/2/2018 6:55:32 PM
Link 1=EA 01 39 E2 6F 03 1C 01 1
Link 10=A2 1B 39 E2 6F 00 18 01 14
Link 11=A2 04 46 48 DE 00 18 01 15
Link 12=A2 03 46 2D 95 0D 17 01 5
Link 13=A2 06 46 48 DE 0D 18 01 6
Link 2=AA 00 39 E2 6F FE 1C 00 2
Link 3=E2 01 39 E2 6F 00 00 01 3
Link 4=A2 FE 39 E2 6F FF 1F 01 4
Link 5=E2 01 46 2D 95 00 00 03 7
Link 6=E2 01 46 48 DE 00 00 06 9
Link 7=A2 01 48 1E CE CC 1C 01 10
Link 8=A2 1A 39 E2 6F 00 18 01 12
Link 9=A2 05 46 48 DE 00 18 01 13
LinksDownloaded=1
NumLinks=13
PollingInterval=0
Protocol=3
RecentDatabaseDelta=1
TotalInteractions=78
From the UI:
Device Link Table
Link #6 Switch/Load controls KPL Living Room Keypad Button D (46.48.DE)
Link #5 Switch/Load controls Kitchen Keypad Button C (46.2D.95)
Link #1 Switch/Load has local control reporting to HomeSeer
Link #3 Switch/Load has local control reporting to HomeSeer
Link #11 Switch/Load is controlled by KPL Living Room Keypad Button B (46.48.DE) - On Level: 0%, Ramp Rate: 8 Sec.
Link #9 Switch/Load is controlled by KPL Living Room Keypad Button C (46.48.DE) - On Level: 0%, Ramp Rate: 8 Sec.
Link #13 Switch/Load is controlled by KPL Living Room Keypad Button D (46.48.DE) - On Level: 5%, Ramp Rate: 8 Sec.
Link #12 Switch/Load is controlled by Kitchen Keypad Button C (46.2D.95) - On Level: 5%, Ramp Rate: 19 Sec.
Link #7 Switch/Load is controlled by Kitchen Light (48.1E.CE) - On Level: 80%, Ramp Rate: .5 Sec.
Link #2 Switch/Load is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
Link #4 Switch/Load is controlled by HomeSeer using Hub Group #254 (HomeSeer All Devices Group) - On Level: 100%, Ramp Rate: .1 Sec.
Link #8 Switch/Load is controlled by HomeSeer using Hub Group #26 Registered Group #4 'Living Room Downstairs Dim' - On Level: 0%, Ramp Rate: 8 Sec.
Link #10 Switch/Load is controlled by HomeSeer using Hub Group #27 Registered Group #5 'Living Room Movie' - On Level: 0%, Ramp Rate: 8 Sec.
Old January 5th, 2018, 02:17 PM
mnsandler's Avatar
Insteon Overlord
I need to setup a couple of switches on the bench, and test this over the weekend.
Old January 8th, 2018, 04:41 PM
mnsandler's Avatar
Insteon Overlord
i think i have a fix for you to test. what's your availability to test over the next few days?
i'll post a new beta when i hear back.
Old January 11th, 2018, 09:05 AM
mnsandler's Avatar
Insteon Overlord
I've added logic for the plugin to check the responder link values and use them when sync'ing a responder device. Try beta version 3.0.6.24 in the Updater.
Old January 17th, 2018, 12:49 PM
Thanks Mark!
I'm installing the beta now and will report back.
Old January 19th, 2018, 11:19 PM
Alright, so I'm on version 3.0.6.25.
Still having the same problem.
If I press the physical KPL button all the appropriate lights dim/turn off.
If I click the HomeSeer KPL button all the lights controlled by that KPL turn on at 100% brightness.
Old January 19th, 2018, 11:34 PM
mnsandler's Avatar
Insteon Overlord
strange. this works in my test scenario.
can you post just the "is controlled" links from the devices that are controlled by the kpl btn.
can you also post a detailed log snippet after you press the homeseer kpl button
Old January 20th, 2018, 12:40 AM
I clicked KPL Kitchen keypad button C "Night" at 11:27:26.
This should have:
Turned off Switch Kitchen Light
Turned off Switch Kitchen Pendands
Dimmed Switch Kitchen Sink Light to 5%
Instead it:
Turned on the Switch Kitchen light 100%
Turned on Kitchen Pendants 100%
Turned on Sink Light 100%
Here are the 'is controlled' links from the responder devices:
Kitchen Island Pendants
Link #14 Switch/Load is controlled by KPL Living Room Keypad Button B (46.48.DE) - On Level: 20%, Ramp Rate: 8 Sec.
Link #10 Switch/Load is controlled by KPL Living Room Keypad Button C (46.48.DE) - On Level: 20%, Ramp Rate: 8 Sec.
Link #16 Switch/Load is controlled by KPL Living Room Keypad Button D (46.48.DE) - On Level: 0%, Ramp Rate: 21 Sec.
Link #5 Switch/Load is controlled by KPL Kitchen Keypad Button B (46.2D.95) - On Level: 80%, Ramp Rate: .5 Sec.
Link #15 Switch/Load is controlled by KPL Kitchen Keypad Button C (46.2D.95) - On Level: 0%, Ramp Rate: 1 Min.
Link #1 Switch/Load is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 0%, Ramp Rate: 6 Sec.
Link #3 Switch/Load is controlled by HomeSeer using Hub Group #1 (Button Control Group) - On Level: 0%, Ramp Rate: .5 Sec.
Link #8 Switch/Load is controlled by HomeSeer using Hub Group #1 (Button Control Group) - On Level: 0%, Ramp Rate: .5 Sec.
Link #9 Switch/Load is controlled by HomeSeer using Hub Group #26 Registered Group #4 'Living Room Downstairs Dim' - On Level: 20%, Ramp Rate: 8 Sec.
Link #13 Switch/Load is controlled by HomeSeer using Hub Group #27 Registered Group #5 'Living Room Movie' - On Level: 20%, Ramp Rate: 8 Sec.
Link #17 Switch/Load is controlled by HomeSeer using Hub Group #32 Registered Group #7 'House Goodbye' - On Level: 60%, Ramp Rate: 30 Sec.
Kitchen Light:
Link #10 Switch/Load is controlled by KPL Living Room Keypad Button B (46.48.DE) - On Level: 0%, Ramp Rate: 2 Sec.
Link #8 Switch/Load is controlled by KPL Living Room Keypad Button C (46.48.DE) - On Level: 15%, Ramp Rate: 8 Sec.
Link #9 Switch/Load is controlled by KPL Living Room Keypad Button D (46.48.DE) - On Level: 0%, Ramp Rate: 21 Sec.
Link #6 Switch/Load is controlled by KPL Kitchen Keypad Button A (46.2D.95) - On Level: 80%, Ramp Rate: .5 Sec.
Link #12 Switch/Load is controlled by KPL Kitchen Keypad Button C (46.2D.95) - On Level: 0%, Ramp Rate: 30 Sec.
Link #1 Switch/Load is controlled by HomeSeer using Hub Group #0 (i2CS Registration Link) - On Level: 100%, Ramp Rate: .5 Sec.
Link #11 Switch/Load is controlled by HomeSeer using Hub Group #32 Registered Group #7 'House Goodbye' - On Level: 0%, Ramp Rate: 30 Sec.
Kitchen Sink Light
Link #12 Switch/Load is controlled by KPL Kitchen Keypad Button C (46.2D.95) - On Level: 5%, Ramp Rate: 19 Sec.
Link #7 Switch/Load is controlled by Switch Kitchen Light (48.1E.CE) - On Level: 80%, Ramp Rate: .5 Sec.
Link #15 Switch/Load is controlled by HomeSeer using Hub Group #32 Registered Group #7 'House Goodbye' - On Level: 0%, Ramp Rate: 30 Sec.
Detailed log:
Jan-19 11:27:37 PM Insteon Received a Direct ACK from KPL Living Room Keypad (46.48.DE): 46 48 DE 39 E2 6F 2F 2E 00
Jan-19 11:27:37 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 to locate next possible STX
Jan-19 11:27:37 PM Insteon Received STX 0x50 (Raw Insteon Rec):46 48 DE 39 E2 6F 2F 2E 00
Jan-19 11:27:37 PM Insteon ..Got Hub Response 02 62 46 48 DE 1F 2E 00 00 09 23 00 00 00 00 00 00 00 00 00 00 A6 06
Jan-19 11:27:37 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:37 PM Insteon ..My XML buffer begins with: 02624648DE1F2E0000092300000000000000000000A60602504648DE39E2 6F2F2E
Jan-19 11:27:35 PM Insteon Sending http://10.10.100.248:25105/3?0262464...00000000A6=I=3
Jan-19 11:27:35 PM Insteon Sending command 02 62 46 48 DE 1F 2E 00 00 09 23 00 00 00 00 00 00 00 00 00 00 A6 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:35 PM Insteon Setting status and value for device 48.08.31:1. Old status:0 Old Value:0, New Status:2 New Value:100
Jan-19 11:27:35 PM Insteon Received a Direct ACK from Switch Kitchen Sink Light (48.08.31): 48 08 31 39 E2 6F 2F 11 FF
Jan-19 11:27:35 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Jan-19 11:27:35 PM Insteon Received STX 0x50 (Raw Insteon Rec):48 08 31 39 E2 6F 2F 11 FF
Jan-19 11:27:35 PM Insteon ..Got Hub Response 02 62 48 08 31 0F 11 FF 06
Jan-19 11:27:35 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:35 PM Insteon ..My XML buffer begins with: 02624808310F11FF06025048083139E26F2F11FF
Jan-19 11:27:33 PM Insteon Sending http://10.10.100.248:25105/3?02624808310F11FF=I=3
Jan-19 11:27:33 PM Insteon Sending command 02 62 48 08 31 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:33 PM Insteon Setting status and value for device 48.08.B0:1. Old status:60 Old Value:60, New Status:2 New Value:100
Jan-19 11:27:33 PM Insteon Received a Direct ACK from Switch Kitchen Island Pendants (48.08.B0): 48 08 B0 39 E2 6F 2F 11 FF
Jan-19 11:27:33 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Jan-19 11:27:33 PM Insteon Received STX 0x50 (Raw Insteon Rec):48 08 B0 39 E2 6F 2F 11 FF
Jan-19 11:27:33 PM Insteon ..Got Hub Response 02 62 48 08 B0 0F 11 FF 06
Jan-19 11:27:33 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:33 PM Insteon ..My XML buffer begins with: 02624808B00F11FF0602504808B039E26F2F11FF
Jan-19 11:27:31 PM Insteon Sending http://10.10.100.248:25105/3?02624808B00F11FF=I=3
Jan-19 11:27:31 PM Insteon Setting status and value for device 46.48.DE:5. Old status:0 Old Value:0, New Status:3 New Value:0
Jan-19 11:27:31 PM Insteon -- KPL button Sync, Need to turn button 5 OFF because button 6 went ON
Jan-19 11:27:31 PM Insteon Setting status and value for device 46.48.DE:4. Old status:0 Old Value:0, New Status:3 New Value:0
Jan-19 11:27:31 PM Insteon -- KPL button Sync, Need to turn button 4 OFF because button 6 went ON
Jan-19 11:27:31 PM Insteon Setting status and value for device 46.48.DE:3. Old status:0 Old Value:0, New Status:3 New Value:0
Jan-19 11:27:31 PM Insteon -- KPL button Sync, Need to turn button 3 OFF because button 6 went ON
Jan-19 11:27:31 PM Insteon Checking for keypadlinc button sync on device 46.48.DE src index 6, SrcIsSyncTarget=True...
Jan-19 11:27:31 PM Insteon Setting status and value for device 46.48.DE:6. Old status:0 Old Value:0, New Status:2 New Value:100
Jan-19 11:27:31 PM Insteon Received a Direct ACK from KPL Living Room Keypad (46.48.DE): 46 48 DE 39 E2 6F 2F 0E 03
Jan-19 11:27:31 PM Insteon Sending command 02 62 48 08 B0 0F 11 FF to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:31 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Jan-19 11:27:31 PM Insteon ..Got Hub Response 02 62 46 48 DE 0F 19 01 06
Jan-19 11:27:31 PM Insteon Received STX 0x50 (Raw Insteon Rec):46 48 DE 39 E2 6F 2F 0E 03
Jan-19 11:27:31 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:31 PM Insteon ..My XML buffer begins with: 02624648DE0F19010602504648DE39E26F2F0E03
Jan-19 11:27:29 PM Insteon Sending http://10.10.100.248:25105/3?02624648DE0F1901=I=3
Jan-19 11:27:29 PM Insteon Received a Direct ACK from KPL Kitchen Keypad (46.2D.95): 46 2D 95 39 E2 6F 2F 2E 00
Jan-19 11:27:29 PM Insteon Sending command 02 62 46 48 DE 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:29 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 to locate next possible STX
Jan-19 11:27:29 PM Insteon ..Got Hub Response 02 62 46 2D 95 1F 2E 00 00 09 07 00 00 00 00 00 00 00 00 00 00 C2 06
Jan-19 11:27:29 PM Insteon Received STX 0x50 (Raw Insteon Rec):46 2D 95 39 E2 6F 2F 2E 00
Jan-19 11:27:29 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:29 PM Insteon ..My XML buffer begins with: 0262462D951F2E0000090700000000000000000000C2060250462D9539E2 6F2F2E
Jan-19 11:27:29 PM Insteon **Internal transmit attempt failed for CMD: 00 00 00 46 48 DE 0F 19 01
Jan-19 11:27:27 PM Insteon Sending http://10.10.100.248:25105/3?0262462...00000000C2=I=3
Jan-19 11:27:27 PM Insteon Attempting to get a KPL LED status response from Insteon device 46.48.DE
Jan-19 11:27:27 PM Insteon Sending sync command 17 to linked responder device: KPL Living Room Keypad Button D: Night (46.48.DE)
Jan-19 11:27:27 PM Insteon Sending sync command 17 to linked responder device: Switch Kitchen Sink Light (48.08.31)
Jan-19 11:27:27 PM Insteon Sending sync command 17 to linked responder device: Switch Kitchen Island Pendants (48.08.B0)
Jan-19 11:27:27 PM Insteon SyncResponderDevices called for device code: 46.2D.95:3
Jan-19 11:27:27 PM Insteon Sending command 02 62 46 2D 95 1F 2E 00 00 09 07 00 00 00 00 00 00 00 00 00 00 C2 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:27 PM Insteon Checking for keypadlinc button sync on device 46.2D.95 src index 3, SrcIsSyncTarget=True...
Jan-19 11:27:27 PM Insteon Setting status and value for device 46.2D.95:3. Old status:0 Old Value:0, New Status:2 New Value:100
Jan-19 11:27:27 PM Insteon Received a Direct ACK from KPL Kitchen Keypad (46.2D.95): 46 2D 95 39 E2 6F 2F 01 03
Jan-19 11:27:27 PM Insteon PLMBuffer_Clean - Cleared 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 to locate next possible STX
Jan-19 11:27:27 PM Insteon ..Got Hub Response 02 62 46 2D 95 0F 19 01 06
Jan-19 11:27:27 PM Insteon Received STX 0x50 (Raw Insteon Rec):46 2D 95 39 E2 6F 2F 01 03
Jan-19 11:27:27 PM Insteon Sending http://10.10.100.248:25105/1?XB=M=1
Jan-19 11:27:27 PM Insteon ..My XML buffer begins with: 0262462D950F1901060250462D9539E26F2F0103
Jan-19 11:27:26 PM Insteon Sending http://10.10.100.248:25105/3?0262462D950F1901=I=3
Jan-19 11:27:26 PM Insteon Sending command 02 62 46 2D 95 0F 19 01 to Hub, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Jan-19 11:27:26 PM Insteon Attempting to get a KPL LED status response from Insteon device 46.2D.95
Jan-19 11:27:26 PM Insteon CAPIControl: Label=On, Value=100, ControlType=Button
Jan-19 11:27:26 PM Device Control Device: Kitchen KPL Night to On (100) by/from: CAPI Control Handler
Old January 20th, 2018, 04:30 PM
mnsandler's Avatar
Insteon Overlord
when you do this, are you turning button C On or Off?
if see why the devices are responding full On if you are turning C Off (i need to account for this)
Can you try a test when you turn C On and see how the responder react?
Old January 20th, 2018, 06:03 PM
I am turning button C on. I'm using button C as a scene, so turning button C on should turn some lights off and others on at a dimmed level.
Turning button C off turns off all the associated responders.
Old January 22nd, 2018, 02:43 PM
mnsandler's Avatar
Insteon Overlord
please give 3.0.6.26 a try. its in the beta section of the updater.
HTML code is On
Another 5 button scene controller mikedr Lighting & Primary Technology Discussion 0 October 8th, 2015 07:56 PM
Cooper Aspire RF RFWC5 Scene Controler - Partial Scene Control? VirtualPanther Lighting & Primary Technology Discussion 2 January 27th, 2015 10:41 AM
Keypadlinc - Button controlling a scene that contains another button? dandrzejewski Insteon Plug-in (Mark Sandler) 1 December 7th, 2014 12:03 PM
Cooper 5-button Scene to Control Events? veshman HomeSeer Z-Wave Plug-in 5 August 5th, 2012 01:34 AM
4 button scene controller sohcrates HomeSeer Z-Wave Plug-in 3 October 6th, 2008 06:21 PM
