Go Back   HomeSeer Message Board > Thermostat / HVAC Plug-ins > Thermostat / HVAC Discussion
Old January 7th, 2018, 02:44 PM
tome10 tome10 is offline
Incompatible Thermostat Replacement Engineering
I have Lennox iComfort Thermostats, and they're really 'pretty' Thermostats. With that said, I really want HS integration and 'Pretty'. So I have to get a z-wave (No WIFI, No Cloud) Thermostats. Alright, they're all not very 'Pretty' unless they're the Cloud stuff, and even then I don't think they're as pretty as the iComfort. I have the idea to take a Trane or Honeywell, with touchscreen interface (No Buttons on front), and mounting a 7" Tablet running HSTouch in front of the thermostat. I'm thinking the heat from the tablet would interfere with the thermostat's readings. But, If I have other z-wave temp sensors, I could ignore the thermostat's temp reading. I can ignore the Thermostats actual temp reading through programming right? Then we get into the 'Dead Horse' question. Why do I need a thermostat? Z-wave relay, Z-wave Temp Sensors, and a tablet screen running HSTouch, and you have a virtual thermostat with interface. I'm not sure I can ignore the 'Thermostat's' onboard temp sensor. Ideas?
Are there any 4 circuit z-wave relays?
HTML code is On
Floor Plan Eddiie HSTouch™ 0 June 28th, 2012 03:22 AM
Error initializing X10 Interface: Type incompatible Pierre JDS (Stargate, TimeCommander) 1 November 29th, 2005 02:23 AM
Windows Media Player 10 Incompatible? jvanv8 HomeSeer General Discussion Area 2 December 16th, 2004 07:25 PM
parse_message() Error(13) Type incompatible Lesueur Homevision 0 December 14th, 2004 02:58 AM
incompatible version of stargate plugin picta JDS (Stargate, TimeCommander) 4 January 19th, 2004 11:56 AM
