Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > Insteon Plug-in (Mark Sandler)
Insteon Plug-in (Mark Sandler) Discussions related to Mark Sandler's 3rd parth plug-in for controlling Insteon devices via Smarthome's PLM interfaces (the 2412 & 2413 series controllers)
Old January 7th, 2018, 03:20 PM
mrceolla mrceolla is offline
KeypadLinc and Detach Load
I have a few KeypadLincs that do not attach to any load. I cap off the red wire. I grew curious of the 'Detach Load' option in the Insteon device config page. I enabled it on one of my keypads and observed the additional 'Load' device added. I still have a few questions.
Although I'm not using the load wire for anything now, I could not find a way to control the newly added 'Load' device. How does one do that?
Is there any benefit toward the longevity of the device by using the 'Detach Load' option if I do not need to use the load controlling capability of the keypad? The keypads that do not connect to loads are all dimmers, so I wouldn't hear the relay click of the on/off variety. Is the triac doing any work without a load?
Old January 7th, 2018, 04:25 PM
mnsandler's Avatar
Insteon Overlord
the additional 'Load' device should give you the ability to control a connected load using the on and off buttons?
post a screen shot of all the hs devices associated with the kpl if this is not the case.
i don't think there is any benefit of using this feature especially if you don't have a load connected. you might check the smarthome forum.
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon 3.0.6.23 (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire | RFXCOM | NetCAM | MyQ | BLRadar | Jon00 Charting
Old January 7th, 2018, 08:41 PM
Here's a screenshot. I don't have any on/off buttons. Since it's a dimmer, should I have the slider too? And should my original on/off button still have the slider control?
Old January 7th, 2018, 08:44 PM
Ha! I misspelled keypad.
Old January 8th, 2018, 09:43 AM
mnsandler's Avatar
Insteon Overlord
I need to add the on/off/slider to the Load device. the original device will keep its controls as it can be linked to other devices and still control them
Old January 17th, 2018, 03:57 PM
bbuck2002 bbuck2002 is offline
I am using the detached load to power a light that is NOT controlled by the keypadlinc. It works great, except that I do not have the ability to control dim level or ramp speed, it is only giving me ON/OFF controls to use. The dim function DOES work if I use the remote switch press and hold to dim, so I know the dimmer function of the KPL does work. Did I do something wrong in my setting up the KPL, or is this a plugin issue?
Attached Screenshot shows my concern.
Old January 17th, 2018, 05:33 PM
mnsandler's Avatar
Insteon Overlord
i'll have to work on this feature more. i think you are the first to give it a try
Old January 24th, 2018, 06:37 PM
mnsandler's Avatar
Insteon Overlord
i should have a fix for this in the next beta 3.0.6.28
Old January 24th, 2018, 06:38 PM
mnsandler's Avatar
Insteon Overlord
Old January 25th, 2018, 10:51 AM
Excellent news! Thank you!
Old January 25th, 2018, 01:37 PM
mnsandler's Avatar
Insteon Overlord
.28 posted.
please test your device status polling as well (did some code clean up)
Old January 25th, 2018, 02:41 PM
NickTheGreat NickTheGreat is offline
I love the idea of these keypadlinc's.
How bad of an idea is it to try to use them if I have zero Insteon stuff. I'm 98% z-wave as it stands now.
Or is this completely reasonable and common with Homeseer users?
Old January 25th, 2018, 03:32 PM
mnsandler's Avatar
Insteon Overlord
you can use any insteon switch/kpl as a standalone switch without automation. you can even link them manually so kpl btns can control other insteon devices.
i have seen several zwave users implement insteon in their homeseer setup just to get access to KPLs. Controlling ceiling fans with a kpl and a fanlinc seems to be very popular.
Old January 26th, 2018, 03:05 PM
Thanks. That's kinda what I was thinking. Good to know I'm not completely crazy, or at least have lots of company in the looney bin.
HTML code is On
Using a Keypadlinc in 6 Button Mode with Load Toggle fade23 Lighting & Primary Technology Discussion 3 May 9th, 2015 05:57 PM
Detach HS Touch from google play store Aaron19953 Clients - Android 2 March 10th, 2014 05:06 PM
Need help with Keypadlinc skozin Insteon Plug-in (Mark Sandler) 16 July 6th, 2010 11:09 PM
Keypadlinc Load shut off Drake Insteon Plug-in (Mark Sandler) 2 December 14th, 2006 05:46 PM
CPU load and HSCPU load the same? firtha DooCPUMonitor 2 February 17th, 2006 10:15 AM
