Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO
HS2 / HSPRO General discussion about HomeSeer HS2 and HSPRO
Old March 2nd, 2012, 12:00 AM
The Keeper's Avatar
The Keeper The Keeper is offline
Updated to 49, Z wave 'stat no longer polling?
I updated from an earlier version of 2.5 to 49, and now my Z-Wave thermostat (ostensibly a CT30) is no longer being polled. I had no problems with polling before (well, except when the thermostat itself would freak out), and have tried re-optimizing, resetting the Z interface, restarting HS, disabling polling and re-enabling. I can manually refresh the status via http://localhost/ZWStat_status, so I know it can be communicated with.
I have polling set as 234 seconds, and as of 10:57P, here's the status:
Temperature: 61°F
Setpoint (Heat): 50°F
Mode: Heat
Mode (Operating): Heating
Fan: Auto
Z-Wave Interface Gas Thermostat Control Z14 (14) Z-Wave Thermostat Today 10:19:04 PM
Any suggestions?
Chris
Old March 2nd, 2012, 12:31 AM
Rupp's Avatar
Rupp Rupp is offline
Try a search as this has been covered extensively. You will need to use hs.polldevice or roll back to a previous version.
-Rupp
Old March 2nd, 2012, 09:12 AM
The Keeper's Avatar
Ok, will do, thanks for the info.
Just curious, what is the advantage of not allowing autonomous polling?
Chris
Old March 2nd, 2012, 09:36 AM
Rupp's Avatar
Chris
I'm still waiting on an answer for this issue but I believe it's a bug. Rick made a change so that setting polling on the stat didn't poll all of the children devices because there was too much polling going on. This change, I believe, broke the ability to set polling on the stat. The work around is to use the HomeSeer poll function.
Old March 2nd, 2012, 10:05 AM
Rupp's Avatar
Good news, this is fixed in HS version .51 to posted in the next few days.
Old March 2nd, 2012, 10:23 AM
The Keeper's Avatar
Glad to hear it.
Chris
Old March 2nd, 2012, 10:45 AM
Olbrit's Avatar
Olbrit Olbrit is offline
That's great news. Hopefully it will also fix polling of other devices too.
Old March 2nd, 2012, 10:52 AM
Rupp's Avatar
The new HS version has been posted to https://homeseer.com/downloads/
Old March 2nd, 2012, 02:32 PM
neiltimms's Avatar
neiltimms neiltimms is offline
Rupp, does this mean we no longer have to poll with an event?
Running HS PRO V2.5.0.49 & HS Pro V2.5.0.51
Old March 3rd, 2012, 01:43 PM
The Keeper's Avatar
Thanks, appears that autonomous polling is working again.
Old March 4th, 2012, 11:21 AM
pkitch pkitch is offline
Seer Plus
I don't see .51 posted.
Old March 4th, 2012, 02:09 PM
The Keeper's Avatar
lol, no, I guess not. Was there a recall on that point release?
Old March 4th, 2012, 02:57 PM
Pete's Avatar
Pete Pete is offline
It was yesterday a few hours after release and installed by a number of HS users.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers
HS3 Pro & Lite
Edition Beta 3.0.0.398 | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Old March 25th, 2012, 10:01 PM
kaffeene's Avatar
kaffeene kaffeene is offline
I just updated to .52 from . 49 and the polling feature for the thermostat doesn't seem to be working still. I also tried [ hs.PollDevice "q18" ] and I can't even get that to execute. Perhaps I am missing something small.
edit: Alright I was able to set up an event and execute an immediate command to poll the t-stat. However HS will not poll using the config page of the device.
Old April 16th, 2012, 09:30 PM
Ericryherd's Avatar
Ericryherd Ericryherd is offline
My CT20 stopped responding after I updated to .52. Turns out that somehow it had lost it's ZWave connection so I had to reset and re-add it to the ZWave network and now it's working fine.
I don't know how it happened but the little radio tower symbol on the screen was blank and HS just kept erroring on it until I finally re-added it to the network.
All is good now (so far).
Old April 16th, 2012, 10:08 PM
joegr joegr is offline
Originally Posted by Ericryherd View Post
My CT20 stopped responding after I updated to .52. Turns out that somehow it had lost it's ZWave connection ...
I don't know anything about a CT20, but my CT30 did that (and other problems) enough that I replaced it with another brand. I've read of the same complaint from others.
