Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 Plug-In Development
HS3 Plug-In Development Discussions related to developing plugins for HS3.
Old November 18th, 2013, 03:42 PM
bartbakels's Avatar
bartbakels bartbakels is offline
Growl/Prowl Plugin HS3?
Hi all,
Is there a prowl or Growl plugn in the making? I just loved the HS2 version of this plugin.
Thanks in advance
Bart
Old November 18th, 2013, 11:41 PM
bernieb bernieb is offline
Not that I know of ... the original author has been missing in action for quite some time.
I am using Prowl as well and would like to see a solution.
The closest that I can find, and it would suit my needs, is a script that someone wrote a while back. http://forums.homeseer.com/showthrea...t=growl+script
See post #25
I haven't tested it myself with HS3 but the I contacted the script author and he doesn't any issues to implement with the new version.
Let us know if you try it.
Old November 22nd, 2013, 02:36 PM
bartbakels's Avatar
hi all,
I tested it and created a script;
sub Main (byVal msg_short As String)
Dim url
Dim url_response
url = "apikey=YOURAPIKEY&application=HS3&event=" &msg_short
url_response = hs.URLAction("https://api.prowlapp.com/publicapi/add", "POST", url, "Content-Type: application/x-www-form-urlencoded")
End Sub
save this as xxxx.vb
and call it with Main and as parameter the text that you want to send.
regards bart
Old November 22nd, 2013, 10:38 PM
Thanks, I'll give it a shot
Growl plugin jlrichar HomeSeer General Discussion Area 39 March 13th, 2017 12:07 PM
Growl and Prowl tips mstrickland HomeSeer General Discussion Area 16 June 9th, 2012 08:56 AM
Growl plugin: who is using it? Does it work? DJF3 Script & Plug-In Library 0 January 26th, 2012 05:12 PM
Growl plugin? heatvent Script & Plug-In Library Discussion 1 January 31st, 2010 12:04 AM
Prowl and Growl Jroberts HS2 / HSPRO 16 August 3rd, 2009 11:22 AM
